back to carbs
Results 1 to 10 of 15
Like Tree28Likes
Thread: back to carbs
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,730
    back to carbs
    I have a 95 that I have had with me for some years. It has always had a purge, that is going along just fine at a constant rate, but would cut out a bit. When getting on it not a miss.
    Just replaced the intake boot on the cylinder, put it back on thinking that was the issue. Still will not start. Took it apart again, seemed a clogged needle valve, as there was no gas in the bowl. Cleared that, put it back in still no start. Checked spark, plenty.
    Anyone else have one of these older carbs that can give me any ideas, I would be grateful. I will be taking it apart tomorrow again and will get the aircompressor fired up. Such a pain to take one out of the bike due to the way the cables are hooked up, thanks.
    Ken likes this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,974
    Quote Originally Posted by plumbstraight View Post
    I have a 96, pre-ethanol bike. I see you just changed the intake boot on the cylinder. How is the intake boot from the air cleaner to the carb? My air intake tube didn't fit properly which caused the bike to run a little lean at high speeds which would cause a thump where it was lacking enough fuel for the high speeds. I corrected the air intake tube over the carburetor and it stopped the thumping. Technically we may need to actually put a little bigger jet since these bikes need more fuel with the ethanol to make the same power especially at higher rpms. You may want to clean the petcock and fuel filter just to make sure all that gas isn't being restricted at all.
    mhomadness likes this.
    1993 TW200 just over 46,000 miles
    Senior Member Scooterbrained's Avatar
    Sep 2019
    NE Florida
    204
    If you open the drain screw at bottom of the bowl, does fuel drain out? Easy way to make sure float/needle valve is clear and petcock is working.
    plumbstraight and mhomadness like this.
    '16 Yamaha TW200 '08 Kawasaki Vulcan Nomad '07 Kawasaki KLX250 '93 BMW R100GS Bumblebee (Mothballed)
    '99 Tacoma SR5 4WD '58 Willys CJ5 '90's Honda 4514 hydro riding mower '90's Honda 5013 compact tractor 4WD & 4W Steering
    2,730
    Quote Originally Posted by Scooterbrained View Post
    I took it all apart as far and the float and needle valve. There was a restriction and I cleared that. Good idea to check by pulling the bottom screw, I did not notice it earlier.
    Mar 2012
    Boonville, No.-Calif.
    1,366
    On my carb, California mod. carb, seems like there was a small freeze plug / cover over the pilot jet screw. If you have that, pull that plug, remove that pilot jet screw & clean in there real good. It sure helped my bike. That jet can really influence the low end to mid range performance.
    Also try putting a small spray of starting fluid into the air cleaner box before you pull the carb off tomorrow, just to confirm that it's a fuel problem. m.
    1997 TW with some modsHidden Content Pike'n the Boont region since 1989!
    Have a Bahl Dee! Hidden Content
    Mar 2012
    1,366
    Here's a good read done by qwerty years ago.
    https://www.tw200forum.com/forum/tec...rb-tuning.html
    It helped me zero in on my carb, I did change to a #118 jet, and shimmed the needle. I opened the pilot jet screw aprox. 2 turns.
    This in my case helped, and my bike runs very well at around the same elevations you ride at. (sea level to 5k ft.)
    Hope this helps. m.
    plumbstraight and Ken like this.
    Mar 2012
    1,366
    Once the carb is back on the bike, & the bike is running, that pilot jet screw can be tough to get to...
    Here is some advice from the legendary "Lizdbrth" :
    "Some guys use a bit from a 4-way screwdriver, shorten the handle on a stubby screwdriver, etc.
    Your pilot circuit is open 24/7, so ta speak, so it's a component of your total fuel volume at w.o.t.
    That's why it's so important. If your pilot circuit is lean or rich the cumulative effect of whatever main jet you install will be leaner or richer accordingly. Hope that makes sense."
    https://www.tw200forum.com/forum/tec...y-93-carb.html
    Hope some of this helps. m.
    Member nobade's Avatar
    Aug 2011
    Albuquerque
    39
    I really like my mod to the idle mixture screw. Drilled it and soldered a 1/16" Allen wrench to it. That hangs down enough so I can adjust the mixture without tools and I can keep track of turns by being able to see where the end is pointed.
    In your case I would make sure the pilot jet is not clogged. That's a small hole and it easily plugs up. If you find it closed, I'd recommend getting one or two steps bigger from jets r us and you'll have an easier time dialing it in correctly.
    Sent from my SM-J737V using Tapatalk
    2,730
    Took the carb off again after clearing the needle valve. It was restricted so figured that was it. So pulled it off and took every screw out of it. Used my torch tip cleaners to make sure those small orifices were open. Put it all back together and it fired up at the touch of the starter. All is good.
    Thanks to all for thei input.
    Ken, Purple, admiral and 2 others like this.
    Junior Member Bern's Avatar
    Aug 2019
    7
    Dumb question for you plumb: I’m up in Maine and put the girl away for the winter with a battery tender. Do you think I should run the fuel out? I was thinking I would set fuel to off and run her until she sputters out. Never having had a motorcycle wasn’t sure this was necessary. Any advice would be appreciated.
