Problem removing float hinge pin ( older style carb )
Results 1 to 10 of 10
    Senior Member Bucknutz's Avatar
    Apr 2012
    Lower Hudson River Valley of The Communist State of N.Y.
    487
    I was hoping somebody would have a suggestion on how I should remove the hinge pin. I am in the process of taking apart the carb on my 95 T dub. It was so gunked up that the throttle slide was in a fixed state. The main jet is clogged shut. ( going with a 118 anyway ) I have gotten most of it apart and cleaned, except I am having trouble getting the float hinge pin out so I can clean the float valve. Is there a tip to getting this hinge pin out? I thought I would post up and ask before I break something. I was about to try a softy brush on a dremmel to clean up the shaft. ( although, I really can't see any build up ) Usually, when I've taken other carbs apart, you have to be careful that they don't fall out accidentally, not so in this case. Am I missing something? Thanks for your suggestions. Dave
    Apr 2012
    487
    I just read through the pinned thread on the new style carb about removing the float. Tomorrow, I will take a closed look to see if the older style carb has an arrow. Hopefully, it will be the same process. Dave
    Pleasanton, CA
    5,670
    Hi Dave,
    Yes, there is a tip on getting that pin out and I know it is somewhere on this forum. Those support posts are fragile and easily broken if you are not careful. Please wait until someone comes along with this information before you attempt to remove that pin.
    Brian
    Pleasanton, CA
    5,670
    Here's the thread that I was thinking of:
    https://tw200forum.com/index.php?/top...buretor-float/
    Apr 2012
    487
    Yes, that's the one I found after I posted my first post. ( thanks ) I am guessing that the earlier carb is similar, tomorrow will tell. Dave
    Sep 2012
    Northwestern Oregon
    1,092
    This is the newer carb, but in any case, be careful or you will end up with this:
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    tiny punch smaller in diameter then pin and should "tap" right out.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,389
    Quote Originally Posted by importmech View Post
    On his 18 year old gunked up carb, I suspect it won't tap out easily.
    If you are going to try the tap method, I would suggest applying penetrating oil, and make sure you put a support under the post when you tap.
    I can't count the number of carbs I've seen with broken float posts.
    jb
    Apr 2012
    487
    Well, it's out. ( and no broken arm ) It was in there pretty good. I want to note that on the older style carb, the pin pushes out in the direction away from the choke knob side of the carb. ( very small arrow ) As I read the pinned thread that explains the method for the newer style carb, it appears that the direction of removal is just the opposite. ( towards the choke knob side ) Thank you all for the help. Rubber side down, Dave
    Junior Member zoolander's Avatar
    Nov 2010
    24
    Quote Originally Posted by Old White Truck View Post
    For this style float, what is the proper float adjustment height? (I have a manual that shows a different type of float)
  1. Replaced float valve assy and main jet - now problem
    By seantx in forum Technical Help
    Last Post: 04-07-2013, 04:15 PM
  2. Removing the Carburetor Float
    By jbfla in forum Technical Write-Ups
    Last Post: 06-26-2012, 03:36 AM
  3. Help removing needle from old style carb
    By kennethshaw in forum Technical Help
    Last Post: 04-18-2012, 05:13 AM
  4. Newer CV carb vs. older carb. MPG
    By number356 in forum Technical Help
    Last Post: 03-28-2011, 11:25 AM
  5. Jet kit for 'older' style carb?
    By catamount in forum Technical Help
    Last Post: 08-11-2010, 08:26 AM
broken carb post float
float pin removal problems
gx160 carburetor broken float hinge pin
how to remove float hinge pin
how to remove float pins from carburetors
how to remove old style hinge pins
problem removing carburetor hinge rod
remove the float hinge pin
removing float hinge from carbs
removing float pin tw200
tw200 float height
