Cdi yellow wire
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Cdi yellow wire
    Junior Member GrantM's Avatar
    Feb 2013
    Eastern Canada
    6
    Hello:
    I ordered and received a cdi for my 1995 tw from partzilla. I seem to have an extra yellow wire. I taped over the end of the yellow wire, held my breath and 260$ cdi but the bike fired up and ran nicely. All the symptoms of idling fine but an inability to rev up appear to be gone.
    Does anyone have any concerns leaving that wire disconnected? I guess the damage would have been done by now?
    Thanks for any comments.
    Grant
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Wait for someone with it fresher on their mind can chime in but NO its not fine. I had wires connected wrong and went over 2,000 before the cdi went taking my stator with it. Very expensive lesson. Don't run that baby til you figure out where it goes.
    Tenaciously Deviant Unwittingly Brilliant
    Jul 2011
    1,123
    Don't cut the yellow wire!!!
    Well, you won't blow up but can't remember what it does. Better safe than kicked off the bomb squad the hard way. Will look it up for you in morning if someone else doesn't chime in
    ITCB
    6,985
    My parts bike came with a spare CDI. The PO said he spent $300 and it didn't run any better with the new one -- it was a carb problem. I noticed the extra wire and decided to use the older CDI with the correct number of wires and after reading this post I am glad I did. I was thinking maybe the yellow wire went to a tach.
    It seems like all things TW start with a "2JX", at least on my '87's. If so maybe "2YG" is significant for some other model that is useable with the TW.
    Feb 2013
    Eastern Canada
    6
    Thanks a lot to all who replied. I am trying to find a good wiring diagram but no luck yet. A sketchy one shows what looks like the yellow wire going to a neutral switch.
    Thanks again.
    Grant
    Nov 2011
    Alabama
    326
    2yg is my '94 so I assume '88-'00.
    Nov 2011
    Alabama
    326
    OK here we go. Assuming you have the correct model stator and cdi, the yellow and brown wires go to your stator. They come from the stator and attach to the wiring harness under the seat. It keeps the colors and attaches to your cdi out of another point on your wiring harness. Shouldn't run without it actually. I ran mine with the yellow and brown wires reversed for 2k before utter destruction.
    6,985
    So what I need is a wiring diagram for an '87.....................or what years have a yellow wire and which years don't?
    Feb 2013
    Eastern Canada
    6
    Thanks for the diagram. I am going to end up with the extra yellow wire I guess since all the other colours matched up nicely....A bit of history... I only had the bike home for a few hours before the idling and rev problem showed up. I isolated it to the cdi after several carb cleans. I noticed the problem went away when moving the bike from a warm to cooler place. II baked the cdi in the oven and could get a ride or two out of it but I never ventured too far. This new one seems to work great but I hope I don't have a 2000 km disaster.
    Thanks again
    Grant
    Nov 2011
    Alabama
    326
    Quote Originally Posted by Tony View Post
    Those came right out of the manual downloaded from this site. The first wiring diagram in the manual is for an '87. The pics I posted are from the end of the manual for later model bikes. It's all pretty sketchy at best but through personal experience I know this is the one to use on my '94.
    P.S.- Still don't think there should be any extra wires much less a yellow one but if it works then good luck to ya!
  1. Yellow Tank Installed
    Last Post: 06-22-2013, 11:18 AM
  2. Burnt red wire
    By snakefoot in forum Technical Help
    Last Post: 07-15-2012, 08:15 AM
  3. WTB front square yellow reflector
    By Retrofit in forum TW200 Classifieds
    Last Post: 07-31-2011, 07:23 PM
  4. Where does this wire go?
    By tok-tokkie in forum Technical Help
    Last Post: 01-07-2011, 12:21 AM
  5. Wiring Question - Where does this wire go???.
    By Grant in forum Technical Help
    Last Post: 12-25-2010, 12:31 PM
1995 tw200 cdi wiring
36r-85540-m0-00
brown wire cdi 85 bw 200
cdi 2jx-85540-m0-00
cdi yamaha tw 200
cdi yamaha tw 200 modelo 94
tw 200 cdi yellow wire
tw200 brown wire to cdi
tw200 yellow and brown wires
wanted 2013 yamaha tw200 wiring diagram
yamaha cdi brown wire
yamaha tw cdi diagram
