Bulbs
Results 1 to 8 of 8
Thread: Bulbs
    Senior Member nfpgasmask's Avatar
    Nov 2010
    Reno, NV
    500
    So my headlight's low beam crapped out already. So much for aftermarket parts from Japan. It uses a weird MICHIBA H4 12V 35/35W 1204 bulb. Now, I can easily find 65/55w H4s, but I am worried, would this burn to hot or blow a fuse or could I use a 65/55w with no issues?
    Thanks - Bart
    Desert, SoCal
    7,369
    Usually you'll only find 35/35 in stock at motorcycle dealers. Fortunately they're a rare exception in that they're cheaper than automotive counterparts.
    Around 15 bucks at Yamaha.
    Your late model's charging system will support a 55/55, but you may get excess heat buildup in that small housing. If it has either a plastic reflector, plastic lens or plastic housing I'd limit it at 35/35. Plastic parts tend to melt with high wattage bulbs and clear plastic lenses will go yellow on you even if they don't outright melt.
    Jun 2011
    AZ
    793
    You can use a LED headlight. I don't see any possible way that can blow a fuse. H-4
    Nov 2010
    Reno, NV
    500
    Thanks, guys. I will see about LED and maybe I will just try a higher wattage bulb. The housing is metal and the lens is glass, so I might be ok.
    Bart
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    If he goes LED,wouldn't he have to change a relay or two?.Unless I've missed the point completely?.
    Apr 2011
    Martinsville Indiana
    2,089
    Pretty sure the 01-up come with a 55w bulb. Piaa makes good bulbs "expensive" or you could do a HID light
    Member Dwight's Avatar
    Mar 2012
    Florida, Maryland, Maine
    42
    Cheapcycleparts.com lists OEM bulb for TW200 years 2003 forward as 12v 60/55w halogen. Sells for $15.89
    Nov 2010
    Reno, NV
    500
    Yeah, I just put a H3 55/65W in and it works, gets hotter for sure, but my headlight is all metal so I hope it is ok. We'll see.
    Thanks - Bart
