Help with inserting the rear carb rubber into the airbox
Results 1 to 4 of 4
    Senior Member turborob's Avatar
    Australia.
    553
    Hi all.
    Any hints on installing the rear rubber 'tube' from the airbox to the rear of the carb?
    I bought a new one as the old one had suffered shrinkage and wasn't properly covering the rear of the carb.
    I haven't removed the airbox, but the carb is out. I had a try this evening to get it in, and I couldn't manage to get it over the second lip. I tried lubing it up with WD40, but still had no success.
    Anyone got any hints for me besides HTFU?
    Thanks,
    Rob.
    Ephrata, WA
    1,125
    So you are trying to get it into the air box right? It was easier for me to take the air box out. I had to take off my seat, tank, shock, and rear wheel to get the air box out. Reason for this is because it takes some force to "pop" it in. With the air box out, you can get a better visual of it and make sure the lip is properly seated. If you don't want to try that, boil some water and stick the boot in it for a few minutes. It will get real soft and then you could probably get it in. Its tough, but doable, so take your time and don't get too upset!
    1990 TW200
    Senior Member bikerjosh's Avatar
    Walnut Creek, CA
    1,066
    Sorry my TW is at my house in the garage w/o pictures I have no idea.
    Josh
    Not all men are capable of greatness, but all possess toughness.
    2001 TW a mod or two maybeHidden Content
    Australia.
    553
    Quote Originally Posted by Rainman View Post
    Legend Rainman!
    Put it in boiling water for a few minutes, went outside and it went in within 10 seconds easy as pie! Not even kidding!
    Infinitely easier than taking off the wheel, shock, box etc!
    I owe you a beer if you ever come to Aus!
    Thanks,
    Rob.
  1. Old airbox boot.. new airbox boot.. still too short
    By silverhead in forum Technical Help
    Last Post: 05-10-2013, 12:36 AM
  2. Rubber Windscreen - and Rubber on Cyclerack
    By APV1 in forum Performance and Customization
    Last Post: 11-12-2012, 06:54 PM
  3. Rubber Foot Pegs
    By lyfestyl in forum General Discussion
    Last Post: 08-15-2012, 09:23 AM
  4. Need: Rear fender rubber pad thingy
    By vn_grnt in forum TW200 Classifieds
    Last Post: 04-06-2012, 04:19 PM
  5. Rubber Plug inside Carb Help Please! QWERTY??
    By Quicksand in forum Technical Help
    Last Post: 03-06-2011, 09:40 AM
