Tw 200 new motor
Results 1 to 7 of 7
    Junior Member Cappa71's Avatar
    Oct 2010
    hi all, I hope someone can help me,
    I broke down my Tw 200 two weeks ago, there was a problem with the oil, lack of it and I didnĀ“t keep the level on properly, so my motor is dead, I donĀ“t know how to say in English but I broke a Biela from the Carburador, I need a second hand motor of a Tw 200, where can I find one??? Please HELP!!!!!
    Thanks
    Member bruisr's Avatar
    69
    Quote Originally Posted by Cappa71 View Post
    Thanks
    eBay
    1993 TW/1200 origional miles/FMF/Clarke Tank/Pro Bend Hand Guards/Pro Taper chain/Larger Foot Pegs/Pro Taper grips/PIAA 35w/Cyclorack/LED stock turn signal conversion/Storage tubes/Kenda 270 5.10 front tire/Glock 45 Handle Bar mount(for the desert runs)!
    Senior Member rm_hm's Avatar
    1,619
    +1 For Ebay
    http://shop.ebay.com/?_from=R40&_trk...All-Categories
    I can't remember if a zongshen gy200 motor will fit. I don't think they have the offset sprocket on them, Spudrider would know for sure.
    Other Ideas
    http://www.bikeboney...a%20tw-200.html
    Senior Member Petrus's Avatar
    Africa
    458
    Quote Originally Posted by Rich View Post
    ....I cant remember if a zongshen motor will fit. Spudrider would know for sure....
    Stay away from cheap Chinese knock off engines.
    Buying cheap engines will cost you lots of money in the future.
    Try to repair your engine or buy a new or used Yamaha motor.
    +2 for ebay
    2008 TW200
    Senior Member wayne's Avatar
    Rathdrum Idaho
    108
    Where are you located?
    Senior Member sinophilia's Avatar
    Aug 2010
    Verona, Italy
    522
    Hi, are you in Spain or somewhere else?
    I've seen a lot of people tear down the TW engine and rebuild it quite easily with the help of forum experts, so you can definitely give it a go if you find the parts, but it may still be pretty expensive, as you usually need to replace quite a lot of stuff after a breakage like that, and have the cylinder rebored. You might be better off buying another TW200, if available in your area, and if you can find an old one for 600/800 euro.
    Red Max - 1996 TW200 - 14/45, 320mm toothed brake disc, X-Racing titanium exhaust, Ricochet skid plate, Mule hitch pins, large pegs, VeeRubber VRM274&275 tires
    Senior Member Mame Shiba's Avatar
    Oct 2010
    Ajaccio, Corsica/Honjō Shi, Japan
    389
    Hi
    easiest way is to find an used engine in better condition and replace the broken parts.
    you can also check there if you have relatives in Japan
    http://auctions.search.yahoo.co.jp/s...ale=0jp&mode=1
    price is around 25,000Ā„
    cheers
    Please contact member MichaelC from San Diego Cal. before asking info or putting comments about tuning parts, motorcycle customization and everything linked to TW in Japan. Thank you very much.
  1. XT-200 - same motor?
    By dpawl31 in forum General Discussion
    Last Post: 06-20-2013, 05:30 PM
  2. sea foam motor treatment
    By gussy78 in forum Technical Help
    Last Post: 05-15-2013, 03:57 PM
  3. ttr225 motor in a tw?
    By stan in forum Technical Help
    Last Post: 11-28-2012, 06:28 PM
  4. Somebody stole my motor!!!
    By xdac in forum General Discussion
    Last Post: 08-16-2012, 08:22 PM
  5. WTB: TW200 motor
    By amolaver in forum TW200 Classifieds
    Last Post: 11-12-2010, 09:02 AM
carbulador mv28p
xt200 forks
yamaha tiwi 200
