2010 Re-timing help?
Results 1 to 8 of 8
    Junior Member HercJerk's Avatar
    Jan 2013
    Kodiak Alaska
    11
    I've been trying to set my timing but the manual I have and the marks on my crank are different. The manual says to line up the arrow with the "T" but my markings are "|----| |" so I don't know what to line up. I tried lining it up on the "I" but the crank always turns 1/8" past it.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Have you turned the crank a little each way past the marks you found? On mine the T is there and the marks you found as well. You do have to look closely to see the cross bar on the top of the T. Are you trying to do cam timing or ignition timing? You can pull the spark plug to avoid the crank turning past the mark. It's probably engine compression that's making it rotate past where you want it. It's also a good idea to use a socket on the flywheel bolt for precision in turning the crank.
    Jan 2013
    Kodiak Alaska
    11
    Yah there is definatly no "T" and I do have the spark plug pulled. I was using a socket and was just barely turning it and it would roll past the "I" EVERY TIME! It's so frustrating!
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Had a Honda 650L...never did find a "T" mark......it actually looked like a "T" on it's side????.....on that forum,folks swore it was an upright "T"????.
    6,985
    Pull the side cover off the head and look at the upper cam chain sprocket. It has a mark on it and it should be at 12:00 when the piston is at top dead center and both valves are closed. If the mark is at 6:00 your valve springs will cause the engine to turn slightly. With the mark at 12:00 (6:00 will work but it will move as you described) look in the little hole and see where the lower mark is pointing.It should be a line just to the left of the T but not as far left as the "H".
    What timing are you changing?
    Senior Member rm_hm's Avatar
    1,619
    Timing thread (with pics)
    http://tw200forum.co...-timing-to-tdc/
    Jan 2013
    Kodiak Alaska
    11
    okay so i had a buddy help me and since there was no "T" we lined it up with the "I" and apparently all i needed was an extra set of hands because he held it in place while i adjusted the timing sprocket and the bike runs fine.
    thanks to all for the help.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    EXCELLENT! Now ride the wheels off that thing.
  1. cam timing to TDC
    By jimbo slice in forum Technical Help
    Last Post: 07-14-2014, 08:47 PM
  2. Timing chain adjustment help
    By kevorwaller in forum Technical Help
    Last Post: 04-15-2014, 09:57 AM
  3. Using a timing light to check a CDI
    By lizrdbrth in forum Technical Write-Ups
    Last Post: 04-07-2013, 07:32 AM
  4. TW Timing
    By SirSmighty in forum Technical Help
    Last Post: 10-06-2011, 01:23 AM
  5. timing chain
    By maupin81 in forum Technical Help
    Last Post: 06-19-2011, 05:04 PM
flywheel timing marks 07 tw 200
tw200 3 marks tdc
tw200 flywheel 3 timing marks
tw200 timing marks
yamaha tw200 timing marks
