DETERMINATION
Results 1 to 4 of 4
Thread: DETERMINATION
    Member dutchbat's Avatar
    Dec 2012
    Holland
    46
    Hey forum ,
    I have a problem that's very annoying. When i try to start my bike (electricaly) it doesn't work, the only way it will start is by push starting it and revving it a little before i can switch is back to neutral.. so after beeing pissed for a while it started looking up the symptomes on google and some other forums, where i discovered that the problem probably was that my main jet was to small (i changed my airfilter to a K&N filter btw). so when i was looking for my jet size in the manual i was stopt emediatly because i couldn't figure out what it was actually saying.. because a 118 jet seems a little small to start of with.. (even though i have a TW125 and not a 200...)
    the manual says:
    Carburetor:
    Type --Y24P
    I.D. mark --5EK1 00
    Main jet (M.J) --#118
    Main air jet (M.A.J) --ø1.4
    Jet needle (J.N) --4C78-3/5
    Needle jet (N.J) --T00
    Cut away (C.A) --2.5
    Pilot air jet (P.A.J) --ø1.3
    Pilot outlet (P.O) --0.8
    Pilot jet (P.J) --#38
    Bypass 1 (B.P.1) --1.0
    Pilot screw (P.S) --2
    Valve seat size (V.S) --ø2.0
    Starter jet 1 (G.S.1) --#60
    Starter jet 2 (G.S.2) --#60
    Float height (F.H)
    Fuel level (F.L) --0 2.0mm
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Tbot,what year is your bike?....what is your elevation in Holland?.If you believe your bike is running lean,i believe you'll want to go up in main jet size.
    Desert, SoCal
    7,369
    Your main jet has nothing to do with starting. Your pilot jet and choke contral that.
    Are you saying that your battery runs down before it starts or that it cranks but won't fire unless you push it?
    If it's the latter your problem is a slow starter not building up sufficient speed to fill the capacitor in the CDI, or weak ignition components.
    Senior Member LittleCowTW's Avatar
    Portland, OR
    152
    +1, check this out. not TW specific but still very informative.
    I run pipe and pods as well and I do not need a bigger pilot jet FYI for my 96 dub. just 2 1/2 turns out on the pilot screw. your probably sitting at a half turn out from the factory and its leaning you out on startup.
    Persistence is the better part of genius.
procycle 118 main jet
