BRING THE LIGHT!
Results 1 to 5 of 5
    Member dutchbat's Avatar
    Dec 2012
    Holland
    46
    I have recently put my new aftermarket tail/brakelight (baja design) on my tw,but, it won't work..
    i have connected ground to ground (black to black) and i've tried to connect the other wires in both possible way's
    but they give the same result.. a constant beem of light.. or no light at all.. is it the wire conected to my brake pedal
    that is broken? or is there something i'm not seeing here..?
    Senior Member jontow's Avatar
    Oct 2010
    Potsdam, NY
    701
    You're gonna need to get out a voltage-tester or multimeter and figure out what wires on the bike do what. If memory serves me, there really ought to be only 3 wires involved. One is ground, the others are probably tail +, and brake +
    If you have a multimeter, connect the black lead to ground and the red lead to the one you suspect is your brake light wire, then turn on the key and grab the front brake lever or step on the rear brake lever. Should go from 0v to ~12.5V.
    1997 TW, well loved, a bit modified.
    1,110
    I wouldn't necessarily assume that any color on the tail light is what you expect...even the black. The wires on my '95 are black=ground, blue=tail, yellow=stop. The wires on my aftermarket tail light are green=ground, yellow=tail, brown=stop,.
    Wired so everything is working correctly is black to green, blue to yellow, and yellow to brown.
    Senior Member niqhowie's Avatar
    Oct 2012
    New Mexico
    123
    Are you sure you didnt get a side marker?
    "Peace be the journey"
    MY BIKE BUILD- Hidden Content
    -2012 tw200
    Desert, SoCal
    7,369
    Take your seat off and use your battery in a process of elimination.
    Connect any two wires to the battery until you get a light. One of those wires will be your ground.
    Combine one of those wires with the remaining wire. If no light, the other one is your ground.
    Then it's just a matter of determining which wire is tail and which is brake. The brighter of the two of course is brake.
  1. trouble with tail light install - DRC Edge Brake Light
    Last Post: 07-13-2017, 08:36 PM
  2. Tail Light Mod
    By mtkd in forum Performance and Customization
    Last Post: 06-06-2013, 06:04 PM
  3. What do you guys bring for camping gear?
    By kennethshaw in forum General Discussion
    Last Post: 10-29-2012, 05:14 PM
  4. Brake light always on
    By tfactor in forum Technical Help
    Last Post: 07-02-2012, 04:43 PM
  5. HID and LED light photos
    Last Post: 04-19-2012, 08:38 PM
tw200 battery elimination
