yamaha tw125 choke
Results 1 to 4 of 4
    Junior Member Laktix's Avatar
    Jun 2011
    6
    Hey guys I drive yamaha tw125 from 2002and my choke cable came off the carb can someone explain to e how to get the starter plunger to hold that cable again or how to get the pluger out all together if i figure out how to post some pictures I will, cheers from Croatia
    Germany, Werdau
    1,014
    Hi,
    I know this problem from my own TW.
    You will need a long pliers (telephone pliers) and a bit of raw force.
    Grab the plunger and try to turn it a bit.
    You can try to clean it with a some fine grinding paper. But don't remove to much material.
    It can hold again on the cable, but I can not promise it.
    In the most cases you have to buy a new plunger.
    One problem: the TW125 is really expensive (~100 EUR). But you can use the SR125 plunger (~50 EUR).
    For pictures you can use imageshack.us
    Regards, Sebastian
    Desert, SoCal
    7,369
    Sebastian, do the 125's use a TK with a cable-operated choke from the handlebars?
    Germany, Werdau
    1,014
    Yes, the TW125 does have a cable choke (Teikei Y24P/1).
    And the SR125 does have the choke button direct on the carb (like the TW200).
  1. tw125 to tw200 or 225?
    By 4evermetalhead in forum Performance and Customization
    Last Post: 01-18-2017, 04:18 AM
  2. Please help a english man with a tw125
    By Elvdaking in forum Technical Help
    Last Post: 01-06-2014, 03:26 PM
  3. carb kit for 1991?? Choke won't choke!
    By manotickmike in forum Technical Help
    Last Post: 06-05-2013, 02:55 PM
  4. Which air filters for a TW125
    By seba in forum Performance and Customization
    Last Post: 04-27-2013, 12:11 PM
  5. Yamaha TW125
    By Havoc in forum Performance and Customization
    Last Post: 03-13-2012, 04:47 AM
teikei y24p choke
tw200 choke stuck
