Other OEM replacement "stock" mufflers for TW200's
Results 1 to 7 of 7
    Junior Member johnquinnell's Avatar
    Apr 2013
    4
    Hi, I'm new to this forum and currently in the process of restoring a TW200 for a friend. The muffler on the stock exhaust is shot and we're not interested in replacing it with a noisier "performance" muffler. TW's being a bit thin on the ground over here in Australia, I'm wondering if any readers would know if any other Yamaha or other bike brands of stock mufflers are a suitable replacement for the TW200 one?
    Thanks
    John Quinnell
    Sydney Australia
    Germany, Werdau
    1,014
    I am not sure, that a exhaust from a other bike will fit.
    But there are replacement exhausts with a low noise level available.
    You should search for exhausts (street legal) for the European market. These exhausts must have a comparable noise level like the OEM exhaust to be street legal.
    These exhausts are marked with:
    - e-certified
    - homologated
    - with EG-ABE
    You can find some exhausts here:
    http://translate.google.com/translat...aha%26typ%3DTW
    Apr 2013
    4
    Thanks for the information. We are definitely seeking a quieter muffler than all those performance type mufflers on offer. We just thought it might be as simple as sliding the muffler section off the exhaust and taking it to a local motorcycle wrecker to see if there are any similar sized/shaped sections available.
    Thanks again.
    John Quinnell
    Germany, Werdau
    1,014
    Hi John,
    an other option is to buy a cheap performance exhaust (with dB-killer) and to modify it.
    It's possible to disassemble the muffler and to weld 2 or 3 small plates of perforated sheet into the perforated inner pipe.
    I made it by the same way on my muffler (on my MX-TW).
    Senior Member rm_hm's Avatar
    1,619
    If your handy with welding and adapting.........
    lizrdbrth posted this awhile back
    Bottom is TTR/XT, top is TW. Yellow arrows are mounting bolt centers. You can also see the amount of dogleg in a TW pipe along with the different, more outboard rear mounting tab required to clear the tire. Generic or non-TW pipes are gunna involve some fiddling. The stockers appear to be nearly identical at first glance, but differ significantly between the three bikes, so be careful with aftermarket stuff.<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252);">
    Apr 2013
    4
    Thanks for that macbig2k1.
    Modifying an aftermarket muffler to quieten down a little has been on the cards with us if another option doesn't spring up.
    Regards
    John Quinnell
    Sydney Australia
    Apr 2013
    4
    Hey Rich, thanks for the pics. It confirms the muffler on our TW has been played around with by the previous owner (probably to get more sound out of it).
    Now I definitely have much food for thought.
    Cheers
    John Quinnell
    Sydney Australia
  1. good replacement chain for use with stock sprocket size
    By grt1982 in forum Technical Help
    Last Post: 07-11-2011, 05:07 PM
  2. Need stock tw200 carb
    By Daltoncoody in forum TW200 Classifieds
    Last Post: 04-18-2011, 07:47 PM
  3. Replacement clutch recamendations, stock, EBC?
    By DBR0051 in forum Technical Help
    Last Post: 01-12-2011, 06:45 AM
  4. Just got my 2007 ALL STOCK TW200....
    By WhackedOutWizard in forum Performance and Customization
    Last Post: 11-06-2010, 05:01 PM
  5. Is odometer stock equipment? / Replacement lever(s)
    By jontow in forum General Discussion
    Last Post: 10-16-2010, 05:00 PM
tw200 muffler guard
