Air box seal kit
Results 1 to 5 of 5
    Member beefcake morris's Avatar
    Dec 2012
    Jacksonville, Fl
    99
    Hello all,
    I am on my last mod until my cyclerack gets here. I bought the seal kit from procycle for the air box. I am hoping that I just install in the air box channel when I remove the air box cover itself.
    Can somebody confirm that for me.
    "I am simply a guy trying to master a very simple machine with very complex dynamics"
    MSF Rider coach
    Ephrata, WA
    1,125
    Quote Originally Posted by beefcake morris View Post
    Hello all,
    Very easy to do. It installs in the groove on the cover.
    1990 TW200
    Dec 2012
    Jacksonville, Fl
    99
    Thank you very much. I just needed to confirm.
    MSF Rider coach
    Ephrata, WA
    1,125
    No problem. I just used a flat headed screw driver to push the new seal in the groove. I got mine from the dealer and the seal was long enough to do two plus TW covers. I stuffed the seal into the groove making sure it wasn't twisted, stretch, or bunched. When it came full-circle, I used a razor blade to cut off the excess, making sure the two ends touched each other.
    1990 TW200
    Senior Member peter's Avatar
    Jul 2011
    Providenciales, Turks & Caicos
    398
    Great post, my seal is sitting in Florida, waiting to get on Friday's boat. Perfect timing of this thread. Ordered it also from ProCycle.
  1. Outer countershaft seal
    By howardgene63 in forum General Discussion
    Last Post: 08-12-2014, 01:34 AM
  2. Fork oil seal replacement
    By canadainshiver in forum Technical Help
    Last Post: 03-02-2013, 07:55 PM
  3. Countershaft Seal/Bearing
    By tickboy in forum Technical Help
    Last Post: 07-05-2011, 06:57 AM
  4. Fork Seal Savers
    By Homeskool in forum General Discussion
    Last Post: 05-13-2011, 03:12 PM
  5. Fork Seal Replacement?'s
    By brownie2 in forum Technical Help
    Last Post: 11-08-2010, 07:08 PM
tw200 air box seal
