Replaced float valve assy and main jet - now problem
Results 1 to 9 of 9
    Junior Member seantx's Avatar
    Feb 2013
    waco, tx
    28
    Replaced the stock 126 main with 130, replaced the float and seat assembly (leaking with petcock on) and it looks like the shim mod and air/fuel plug removal was done by PO.
    Buttoned everything back up. Starts and idles perfect but if I touch - I mean barely touch - the throttle it bogs and dies. I'm 2 full revolutions out on pilot circuit. Did not touch the pilot jet. Have pulled the bowl off again to make sure the new jet is all the way seated but I'm kind of scratching my head now.
    What elements of the carb are suspect with those symptoms? Could the slide be binding?
    05 TDub
    01 VFR
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Mine died the same way you described, as soon as the throttle is cracked. I found a tiny piece of crap in my pilot jet, all's well now.
    Feb 2013
    waco, tx
    28
    Very possible since I had it apart. Will pull the bowl again and run some strands of wire through the pilot. Thanks!
    05 TDub
    01 VFR
    rbm
    rbm is offline
    Jan 2011
    4,300
    I'd remove the pilot and clean & inspect instead of pushing wire through it, the orifice is tiny.
    Feb 2013
    waco, tx
    28
    Seemed to be blocked. No light through it. Blew it out then ran a strand of speaker wire through it. Tiny bit of light through the orifice now...and it won't start at all.
    Time to walk away for a while.
    05 TDub
    01 VFR
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,710
    I had trouble with mine leaking through the float and filling the crankcase. I pulled the carb and did all the checks. Still leaked, so I just turn off the gas. That is going to get old and will take the carb in someday. With only 1900 mi on it it shouldn't be giving me probs.
    Feb 2013
    waco, tx
    28
    Looking at the photo below, does the small spring go above the circlip or below the spacer?
    05 TDub
    01 VFR
    Feb 2013
    waco, tx
    28
    Well this is embarrassing. FYI it goes ABOVE the circlip. You can but it below but it will run like crap and waste an otherwise beautiful Sunday afternoon.
    Bike runs great and lesson learned.
    05 TDub
    01 VFR
    rbm
    rbm is offline
    Jan 2011
    4,300
    Glad you figured it out and thanks for the info. I'm sure this will help someone down the road.
  1. Problem removing float hinge pin ( older style carb )
    By Bucknutz in forum Technical Help
    Last Post: 04-15-2013, 05:25 PM
  2. Stuck needle float valve Seat
    Last Post: 04-06-2013, 09:55 PM
  3. Carb float needle valve seat question?
    By Twowheeler in forum Technical Help
    Last Post: 01-08-2013, 12:34 PM
  4. Replies: 28
    Last Post: 08-30-2011, 03:26 PM
  5. Late Model Float Valve Adjustment Dimension
    By zbigman in forum Technical Help
    Last Post: 02-17-2011, 09:50 AM
