Ultrasonic Parts Cleaner
Results 1 to 4 of 4
    6,957
    I went to Harbor Freight and bought their large ultrasonic cleaner. Normally $99.99 but was on sale for $79.99 plus the 20% off coupon it came to almost $64. I am happy!
    Dieing to try it out I scrounged some old carb parts (I had them because I never throw anything out), half filled the tub with about 1 part Simple Green and 4 parts water, tossed in the parts and turned it on for default 180 seconds.
    If the rubber on the tip is still sort of soft this float needle valve would still be useable.
    Before:
    After:
    Before:
    After:
    Take a slightly abrasive rubber cone and smooth the seat, the spot where the rubber tip from above makes the seal, add a new o-ring, and I bet this would work.
    This jet is junk but here is the before and after. Note the hole is pretty clean after one time in the ultrasonic cleaner.
    I bet "ultrasonic-ing" the the entire carb. body would do wonders cleaning all the little passage ways.
    Using the ultrasonic cleaner just cleans. It removes dirt and corrosion. It doesn't smooth or polish.
    The next time I take a carb. apart I will definitely be using it. It seems to clean at least as well, if not better, as blasting the parts with aerosol cans of carb cleaner. I like it.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    Nicely done, Tony.
    Did you use the "heat" setting? Mine seems to work better that way.
    Did you try running the parts through for more than one cycle?
    jb
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    Wow! I like it! I may have to look into getting one of those...
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    6,957
    Quote Originally Posted by jbfla View Post
    Nicely done, Tony.
    jb
    I did use the heat setting but I also started with warm water from the tap. I cleaned several batches of stuff trying different time settings. It seemed most of the corrosion was blown off in the first 15 to 30 seconds -- I was surprised.
    The jet was from the first batch which included many little parts. The float needle valve assembly was the last thing I cleaned and I cleaned it by itself. ( Actually I pulled the plunger and spring out of the end of the needle so there were 4 things being cleaned and stuck it back together for the picture.) IIRC that was 180 seconds worth of cleaning but I doubt the last 90 seconds did much.
    The stated ratio of 1:4 SG to water is more of a guess than an actual measurement, or even estimate.
  1. Replies: 12
    Last Post: 11-07-2016, 02:46 PM
  2. A few parts
    By xdac in forum TW200 Classifieds
    Last Post: 01-02-2013, 03:39 PM
  3. 87 TW parts
    By eaglescall in forum TW200 Classifieds
    Last Post: 06-14-2012, 09:43 AM
  4. Looking for parts!!!!
    By Jerseydeville218 in forum General Discussion
    Last Post: 03-29-2011, 08:58 AM
  5. slight seepage from cleaner (left ) side of bike
    By Muletanna in forum Technical Help
    Last Post: 09-15-2010, 08:41 PM
ultrasonic parts cleaner harbor freight
