Brake pads and shoes
Results 1 to 2 of 2
    Senior Member thumper's Avatar
    Oct 2010
    232
    I'm gonna need both brake pads (front) and brake shoes (rear drum) on both of my 2008 TW's.
    Any suggestions between EBC or OEM brand?
    I've used EBC brand on several other street bikes with good results, but read a couple threads
    from folks who claim they don't work well on our TW's.
    should I stick with Factory yamaha brand or use aftermarket?
    Thanks for any suggestions.
    Igofar
    Senior Member abyssdncr's Avatar
    Sep 2010
    Wichita, KS
    164
    I went with EBC and am not especially thrilled with the performance. I didn't drive it much at all with the OEM skids as they were both pretty much shot when I got the bike. However, braking performance isn't exactly great. I inspected the rear shoes after about 700 miles of use and while the shoes are slotted to help clear the dust, the material is chipping away at the slotted areas and don't inspire much confidence for long term durability.
    Hope this helps...
    2006 TW200, LED tail & turn signals, Clarke XT350 tank, hybrid YZ80 forks, CycleRacks rear rack, Ricochet bash plate, TTR225 header, eBay pegs, MSR high ATV bars, Tusk bar risers, Tusk handguards & deflectors, Tusk KX250 stainless brake line, XT225 speedo cable, 14/47 sprockets, Mule-pin seat latches, 130 main, 0.035" shimmed needle, TW34/M6006 meats.
  1. Baking brake pads
    By Dark Sol in forum Technical Help
    Last Post: 06-18-2013, 07:43 PM
  2. Rear brake shoes directional?
    Last Post: 09-26-2012, 09:50 PM
  3. Brake pads.
    By Two Shoes in forum Technical Help
    Last Post: 02-28-2011, 04:46 AM
  4. Rear Brake Shoes Installation
    By thumper in forum Technical Help
    Last Post: 10-30-2010, 08:29 AM
  5. Front Brake Pads
    By Hendragster in forum Technical Help
    Last Post: 10-08-2010, 04:01 PM
