mileage
Results 1 to 10 of 14
Thread: mileage
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,709
    I set my trip meter and use it as a gas gauge. I just turned 2000 mi on an 03 TW. Just filled it and according to the math it's getting 50mpg. I know something is not right. I do weigh a bit, 270, and when going to town hit the freeway at 60mph if the wind is not blowing into my face. I dropped the rear sprocket a few teeth and low is what 2nd use to be and 5th is like an overdrive. Mostly run 25-45 so what should I look into. I am about 75ft above sealevel.
    Frosty Hollow
    12,979
    With stock gearing (14/50) on an 05 and about your weight, I checked my mpg yesterday with mostly highway use this time 55-60mph = 56mpg, which is what I normally get with mostly highway use. When I ride the FS logging roads (15-25 mph), I usually get around 75 mpg, but I ain't been in the woods much this year...yet!
    2,709
    Thank you for the reply. Makes me feel a lot better. I see some talk of 90-100, must be all downhill riding.
    Member Uwdlk2no2's Avatar
    Dec 2012
    Mississippi
    84
    I also am averaging around 50mpg and I weigh roughly the same as you do. I'm guessing that this may be the normal for those of our stature :-)
    Lance
    2013 TW200
    2003 TW200 (Wife's Bike)
    2013 Ultra Classic Limited
    2008 Street Glide
    Member Lonesome Dave's Avatar
    Feb 2013
    Black Hills, South Dakota
    41
    I agree with Admiral and Uwdlk2no2. I weigh about the same and I've always got about the same mileage. I believe "dropping a few teeth" as you say could actually lower your mileage considering the load and engine size. Maybe 1 tooth would increase mileage with your weight. If you were 100 pounds lighter, dropping 2 or 3 teeth would get you better mileage and still have enough power. I went 4 teeth larger (54), I like the lower end but its pretty buzzy at 55mph. Next time I'll put a 53 on instead.
    Member Drifter's Avatar
    Aug 2012
    Lewiston,Idaho
    96
    I just fueled up,and at 56 miles it took .80 gal. That = 70, but that is all city,and not going over 45 mph.
    1994 TW
    Had but regrettably sold a 1982 KZ1000R Eddie Lawson Replica
    6,956
    Both of my TW's used to get around 55 mpg. Both developed the cylinder base gasket leak so when I took them apart to fix that I installed new rings and lapped the valves in both bikes. Now they both get mid 60's mpg.
    I wish I had done a compression test prior to doing the work but I didn't. BTW, one bike is 14t/50t and the other is 14t/55t.
    Senior Member 671tdub's Avatar
    Dec 2012
    guam
    267
    im 165lbs, 14/50, cruise 50mph, rolled up to 65mph a couple times, all road miles, no dirt miles, dirty oil and lower then max spec tire pressure = 90mpg my best so far. i got 70 mpg just ridin up and down street with my son on one tank. i have a 14/47 oring set but not sure i want to put it on now lol !!!
    2006 tw200
    Senior Member Swamp's Avatar
    Apr 2013
    Michigan Territory
    108
    Well, I can finally add something here! I just finished my first tank, and after filling up, my mileage was 76 mpg. My commute to work is 18.5 miles, with a max speed of 45 mph. I have a couple of good long stretches cruising at 35 and 45 mph. I'm 6 ft, 220 lbs!
    I'm not twisting the throttle hard either! I know, kinda boring!
    Swamp
    2006 TW200
    Senior Member jckosnow's Avatar
    Sep 2012
    Maine
    177
    just did the math and I'm at 68mpg. all road miles (this time) top speed 50, but mostly cruising at 40. and I ride like an idiot and wring it out all the time. 5'10.5" 195lbs. stock everything,
    2012 TW200, 1993 KLR650, 1992 GSX750F
  1. Great gas mileage
    By Drifter in forum General Discussion
    Last Post: 05-15-2013, 06:27 AM
  2. Tire mileage?
    By Woodi23 in forum General Discussion
    Last Post: 05-08-2013, 07:46 PM
  3. TW GAS MILEAGE
    By Moose in forum General Discussion
    Last Post: 09-04-2012, 05:58 AM
  4. Mileage
    By Pinittowinit in forum General Discussion
    Last Post: 09-29-2010, 08:31 AM
  5. Mileage
    By WINGNUT200 in forum Performance and Customization
    Last Post: 08-25-2010, 09:37 PM
