Dirty Little Trick
Results 1 to 4 of 4
    Senior Member thumper's Avatar
    Oct 2010
    232
    After replacing the base and head gasket in my T-Dubya, I'm now in the process of doing the same thing with the wifes bike.
    I figured out a really simple trick this time around for lining up the cam sprocket index mark with the chain.
    As you probably read in my other post, I was one tooth off on my bike and it didn't run, so I had to tear it apart
    a second time and remove and re-install the cam chain sprocket, etc.
    Anyway, this time around I came up with a really simple, almost fool proof little trick.
    I took the same 14 gauge wire I used before to hold the chain up, only this time,
    I ran it THROUGH the LINK when it was lined up. I then hooked it over a bungie cord hanging from above
    to keep tension on it so there would be no worry about the chain falling off the lower sprocket this time.
    Now all I need to do during re-assembly is verify that the index mark on the crank has not moved, then
    line up the cam chain sprocket index mark at the spot the wire went through and all should be good.
    Hope this helps someone....just thought I'd share.
    Ride safe.
    Junior Member floridakid's Avatar
    Jan 2011
    6
    I'm doing the gasket change soon...thanks for the trick. Did you put the gaskets on dry?
    Oct 2010
    232
    Quote Originally Posted by floridakid View Post
    Yes, the base gasket has some dowels and a couple o-rings, 1 large, 1 small.
    The head was metal.
    Very easy install. Good luck
    Just go slow and check your work often.
    Member chickenwingsmmm's Avatar
    68
    often times on the timing chains of newer cars, there are actually colored links that correspond to timing marks on the sprockets. i know this is true on the newer triton (junk) engines in many fords with multiple overhead cams. basically my point being one could mark on the chain with a soapstone or somthing to aid the reassembly.
  1. Dirty piston?
    By HercJerk in forum Technical Help
    Last Post: 07-06-2016, 05:48 PM
  2. TW200 Does the Dirty
    By Rainman in forum Trails, Off-road, and Adventure Riding
    Last Post: 04-10-2013, 08:51 PM
  3. Trick goes bad or does it?
    By cptrout in forum Off-Topic
    Last Post: 10-17-2011, 05:44 PM
  4. Hard Starting Trick
    By thumper in forum Technical Help
    Last Post: 03-03-2011, 01:49 AM
  5. Another Neat Little Trick!
    By thumper in forum General Discussion
    Last Post: 01-19-2011, 07:43 PM
dirty little trick forum
trick tw 200
