fuel line
Results 1 to 10 of 16
Thread: fuel line
    Junior Member gussy78's Avatar
    Northern Indiana
    24
    Just got a new fuel filter and decided to replace fuel lines also. Any recommendations on brand of fuel lines? Or are they all the same? Also what is the I.D. of the TW's fuel lines?
    '89 TW dark on light blue
    Sep 2011
    Southcoast MAsshole
    2,661
    not sure but you could just shut off the petcock and pull it off and bring it with you to the hardware store...or just take a small slice off the end of it if you have extra slack and bring it with you...i don't think it matters much what fuel line you buy but make sure you get a non-translucent line since gasoline will degrade in sunlight...or i guess you could buy the clear stuff and put some type of sleeve around it...and just so you know there is a fuel screen built into the petcock...sometimes fuel filters slow the flow of fuel in gravity fed systems...buy and extra length of fuel line in case your bike acts up...it's cheap enough...let us know how you make out
    Apr 2013
    Central Iowa, USA
    310
    I insist on Tygon brand fuel line. The stuff I use is yellow.
    It remains flexible and pliable long after any other brands I've ever used. Also with the Yamaha, it doesn't require hose clamps.
    I'm pretty sure I'm using 3/16th inch ID Tygon on my bike.. I keep 3/16" and 1/4" stocked in the garage at all times. It stretches over bigger fittings well.
    The added benefit is you can see through it to know if your line is plugged up and there's no fuel in it. It costs about twice the price of the black rubber junk sold at car parts stores and you usually have to ask for it by name (and usually the kid working at the store doesn't know what it is.)
    They sell it at O'Reilly Auto, Napa, and a local mom and pop shop I do business with.
    1993 TW200
    Tennessee
    1,299
    Ditto on Tygon. Nothing wrong with the thick black stuff, but avoid any other brand of transparent, as they usually crack in the sun. Had to replace some line just yesterday because fuel was going everywhere when you turned the petcock on.
    If it's Tygon, 3/16" will work. The standard stuff at the parts store, you'll probably want in 1/4".
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    Bring an extra length of hose in you tool kit. Had one of those little fuel filters break once on my 3 wheeler while riding at local creek and had to Mcguiver it and hobble on back to truck with small fuel leak.
    Ephrata, WA
    1,125
    Quote Originally Posted by importmech View Post
    Excellent point. I do carry an extra length of hose in my stock tool kit, luckily I have never needed to use it. I'll have to look into that good clear stuff. Where is it sold at?
    1990 TW200
    Apr 2013
    Central Iowa, USA
    310
    I have to ask at the counter for them to go pull it from the bowels of the store, but there should be at least one car parts store in your town that has Tygon. You can buy it online, but it's more expensive online than I get it for locally. I pay about $1.50/foot here for the stuff I have.
    You can buy it on ebay. A foot would last someone with a TW about 20 years I imagine, haha.
    http://www.ebay.com/itm/Premium-Qual...-/170708467731
    1993 TW200
    1,110
    Quote Originally Posted by Rainman View Post
    They have Tygon at our local lawn and garden shop....independent one that sells and services mowers, saws, generators, etc. It's the one they recommend.
    Apr 2013
    Central Iowa, USA
    310
    That's where I first learned about Tygon.. The lawn mower store. I suppose because most lawn equipment fuel line suffers the same fate as motorcycle fuel line. Exposed to the weather 100% of the time, so it tends to harden and crack. There are other premium brands of fuel line as well, but I just recommend NOT getting anything clear in color sold at big box stores. And don't get black rubber fuel line from the car parts store. Motion Pro makes decent rubber fuel line that I believe is made by Tygon and closely emulates OEM Japanese fuel line.
    http://www.bikebandit.com/motion-pro-tygon-fuel-line (spendy of course)
    the cool thing about the TW is it has the least amount of fuel line of any bike I've ever owned. Tygon is way easier to deal with on bikes like a Honda CB750 with four cylinders and not as much space to reach in there and install/pull the fuel lines when you need to.
    The TW is the first bike I've had where cheap fuel line wouldn't probably make me very mad.
    1993 TW200
    Northern Indiana
    24
    I got the tygon. Had to ask for it at o'reillys, it was in the back on a shelf I suppose. Got 4' of 3/16 and 1/4". Sounds like good stuff to have around, easy to find and identify too.
    Silverhead, did you prebend your filter?
  1. Fuel Line Diameter ID?
    By Snake2715 in forum Technical Help
    Last Post: 06-18-2012, 07:42 PM
  2. WTB Front brake line
    By xdac in forum TW200 Classifieds
    Last Post: 06-14-2012, 09:34 PM
  3. Fuel line routing
    By Joe in forum Technical Help
    Last Post: 01-08-2012, 04:24 PM
  4. Theres a fine line between hobby and mental illness
    By Turwilliger in forum Off-Topic
    Last Post: 12-18-2011, 10:36 AM
  5. The Bottom Line
    By vincentdsnt in forum General Discussion
    Last Post: 01-31-2011, 08:53 PM
connect fuel lines on yamaha tw200
fule line routing 1993 yamaha tw 200
inline fuel filter tw200
motion pro tygon fuel line
tygon hose
tygon tubing
what size fuel line needed for 1989 yamaha tw200
