Acts likechain is skipping?
Results 1 to 7 of 7
    Junior Member toddmurdoch's Avatar
    Sep 2012
    Alaska
    12
    Hey guys, my buddy and i were out playing in the mud today on out tw200s, his is 2005 mines a 12. I noticed on mine when powering through mud, it would "clunk" it sounded and felt like the chain skipping a link,or something like that. Then his did it a bunch when under load.
    Any ideas?
    Thanks from alaska
    TOdd
    2012 tw200
    dual sprocket 47/50
    rejetted 130
    Tennessee
    1,285
    Well, how's the chain and sprockets?
    Jun 2011
    AZ
    793
    Chain is probably stretched a little. You can adjust the tension from the axle. Don't forget to adjust your rear brake too. You have to loosen it up.
    Sep 2012
    Alaska
    12
    ok chain is pretty loose on both our bikes,I was hoping itd be something that simple.
    Thanks Guys
    2012 tw200
    dual sprocket 47/50
    rejetted 130
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Quote Originally Posted by ToddMurdoch View Post
    Thanks Guys
    If the chain was that loose that it slipped on the sprockets I'd change them ASAP!
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Chain extremely loose....possibly, coupled with the mud or even a rock getting clogged up in the sprocket....raising the chain,then dropping it back onto the sprocket?.
    Sep 2012
    Alaska
    12
    YEah we were buried in mud, so loose chain, lotsa mud seems to be the culprit.
    Rode again and no problem.
    2012 tw200
    dual sprocket 47/50
    rejetted 130
