special tips for getting stock rear tire off the rim??
Results 1 to 10 of 18
    Senior Member jckosnow's Avatar
    Sep 2012
    Maine
    177
    so I've done my due diligence & read all the old posts and seen hours of YouTube videos. so, any extra tips on getting the rear tire off the rim? I have to replace the tube. I popped it and then green slimed it and that was working so well I forgot to really fix it then i woke up one day & it was flat.... so I RE-green slimed it, pretty dumb but its holding for now. I've got my tire irons and a new tube, just need to get it done!
    2012 TW200, 1993 KLR650, 1992 GSX750F
    Jun 2011
    Dothan, AL
    1,715
    The easiest way for me was to take it to Firestone and ask one of the Techs to put it in the machine and break the bead. I tried doing it myself to no avail.
    2005 TW200 (SOLD)
    2013 DR650
    6,959
    I bought a bead breaker from Harbor Freight. It barely fit the huge TW back tire and I had to use a pipe for extra leverage. It works but barely. I can't recommend it.
    http://www.harborfre...aker-98875.html
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    n2o2 has suggested the easiest way.
    Seems like I have to change 2 or3 tires a season, so I bought a car and truck bead breaker from Harbor Freight.
    http://www.harborfreight.com/bead-breaker-92961.html
    Someone has previously posted how they made a giant lever from 2x4's to break the bead.
    Jb
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Junior Member chainslap's Avatar
    Jan 2012
    26
    May be a bit brutish but I start to pry down with the tool then step on the tire at the bead. Also make sure your tube is good and deflated. Especially with the tw. I use the step method with any tube tire change though and it usually works. I also have a good set of motion pro tire tools. Makes a difference. You may want to try and spray a little lube of sort to get it going. I've found any cheap car interior type stuff works as a good lubricant for getting them off and on. Hope you get it squared away.
    Ephrata, WA
    1,125
    My tire change consisted of a six foot long 2x4, a one foot long 2x4 wedge and the bumper of my truck. Worked great though. I tried my feet (250 pounds), tire irons, floor jack against truck bumper with tire in-between (all that happened was that I lifted my truck into the air with my TW tire and wheel between it), and finally the 2x4 lever method. If you don't have the tools, n2o2diver made a great suggestion.
    1990 TW200
    Senior Member LittleCowTW's Avatar
    Portland, OR
    152
    [quote name='chainslap' date='15 May 2013 - 08:20 PM' timestamp='1368667231' post='76388']
    [/quote0] +1. The right spoons makes the job a breeze.....well, less difficult anyway. Btw there's no rim locks on the
    Tw so the job is easier than the youtube videos your watching.
    Persistence is the better part of genius.
    Member deton8r's Avatar
    Washington State
    64
    I just removed a rear tire a few days ago and here are the tools and some lessons I learned. Before I started I watched a bunch of YouTube vids which were mostly helpful. My TW is my first experience with motorcycle tire changes.
    Tools used:
    - GENSSI Motorcycle Tire Changer Assembly (same as Black Widow but red) - works great for the front and I was able to bread the bead of the rear but the bolt through the hub is too short.
    - Tusk 17" Mega Tire Iron - awesome tire iron highly recommended
    - 2 smaller 8" irons
    - NoMar Yellow Thing - useful to have but not necessary
    - Rim protectors
    On my bike the front bead was easy to bread and changing the tire was pretty simple and straight forward. On the rear, the bead was much harder to break. Currently my rear wheel is completely disassembled to be painted so I can't comment on installing the rear tire yet. I need to pray to the truing gods that I can lace and true my wheel within specs first . I will be using a Tusk Truing and Balance stand for this leg of the project.
    Most helpful video I found:
    [media]http://www.youtube.com/watch?v=Hul4lq0sZC8[/media]
    Balancing:
    If you would like to balance your wheels/tires and don't want to pay a shop or buy seldom used tools go with Dyna Beads. I used these on my Buell starting last year when I replaced the tires on that and they work awesome. I found a post somewhere online where a TW owner reported success with them using 2oz in the front tube and 3oz in the back. I currently have 2oz in my front on the TW and it was very smooth. My new front tire is an IRC GP-1 5.10. I was able to test drive it before tearing into my rear wheel. RockyMountainATV sells a kit with the installation bottle with 2oz and 3oz bag of beads which worked out perfect.
    What not to do
    I used the method shown in the video below to remove the tires from front and rear. Do not use this technique for the rear tire where you flip the wheel over and pull the tire over each side of the rim. It worked fine for the front but I could not flex the rear tire around the rim and ended up cutting the bead with tin snips and cutting the tire off. This tire was trash so it was an option for me.
    [media]http://www.youtube.com/watch?v=sFg44gjjDLA[/media]
    Good luck!
    '95 TW200G - TCI skid, ProTaper bars, amber Jimbo, DMO pegs, IRC GP-1, DG-O w/TTR230 header, Brisk BR12ZC, ProCycle jet kit, K&N filter, DID x-ring, TCI Sequoia rack, storage tube, JNS light
    '04 Buell XB12S Lightning - Drummer exhaust, race ECM, K&N, open airbox, RC right side scoop, Corbin seat, fender eliminator Michelin Pilot Power 2CT
    Sep 2012
    Maine
    177
    thanks y'all! I'll tell you how it goes, it's coming off Saturday or Sunday
  1. wtb stock rear tire
    By mkriley in forum TW200 Classifieds
    Last Post: 06-17-2013, 01:26 PM
  2. Return to Stock Rear Tire - Some Musings
    By vuldub in forum Performance and Customization
    Last Post: 05-16-2013, 10:53 AM
  3. Stock front and rear tire
    By Woodi23 in forum TW200 Classifieds
    Last Post: 04-27-2013, 09:19 AM
  4. wtb stock rear tire
    Last Post: 01-17-2013, 10:32 AM
  5. WTB Stock Rear Tire
    By wrhux in forum TW200 Classifieds
    Last Post: 05-20-2012, 12:59 AM
getting a scooter tire off the rim video
tusk 17 tire iron
tw200 nomar tire cgangwr
tw200 rear wheel bead
