Woodruff Key
Results 1 to 4 of 4
Thread: Woodruff Key
    Senior Member thumper's Avatar
    Oct 2010
    232
    How tight should the woodruff key on the crank be (underneath the rotor)
    The factory yamaha one was short and tight and had to be tapped out with a small brass punch.
    The replacement factory OEM replacement ones are a couple milimeters narrower, and longer (overlap the ends of the slot).
    The sit loose enough to simply push out with your finger.
    I'm concerned they fall out of the slot. Is that possible?
    Is it safe to use the new updated versions?
    Thanks
    Desert, SoCal
    7,369
    Sounds kina hinkie. I'd reuse the old one.
    Desert, SoCal
    7,369
    ...maybe polish any dings of burrs of it with some 600 grit on a flat surface. This needs to be a good, tight fit.
    Senior Member Mark In WA's Avatar
    Southwest Washington State
    165
    If it really is a couple millimeters narrower, they gave you the wrong part.
    Mark
    '10 Truimph Bonneville Std.
how tight should woodruff key fit
how to fit a woodruff key
tw200 offset woodruff key
