Will a 52t sprocket fit?
Results 1 to 5 of 5
    May 2013
    Groton, NY
    2,663
    Hi everyone,
    Will a 52 teeth rear sprocket work with the stock chain or will I have to add a few links? I have the stock 14 on the front.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Pleasanton, CA
    5,691
    Hi Scotti,
    Take a look at your snail adjusters on the rear axle. If they are approximately midrange, you should be okay. If they are less than midrange, you may not have enough adjustment for the larger sprocket to fit.
    Brian
    May 2013
    Groton, NY
    2,663
    The adjusters have about a third of their travel used, the bike has only 500 miles on it so chain wear is minimal now. I'll need a couple of links and a master link if I decide to get the sprocket. Thanks.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Pleasanton, CA
    5,691
    If you want to consider upgrading to an O-ring chain, here is a pretty sweet deal identified by SpudRider. At 132 links it will be plenty long enough (and will need to be trimmed).
    http://www.oemcycle.com/Item/product/900269983
    If you click on the drop down menu for Chain, you will find clip type master links for $1.94.
    http://www.oemcycle.com/Item/product/900271460
    I have one of these chains on order that should arrive this week.
    Stanwood,Wa
    1,880
    I run a 52 and yes you will need to add 4 links. takes 126. Get the deal on the o-ring chain and cut cut it down to 126.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
  1. Replies: 0
  2. Where to buy 15t sprocket?
    By Beewerks in forum Performance and Customization
    Last Post: 10-17-2011, 12:56 PM
  3. 47t sprocket?
    By [email protected] in forum Performance and Customization
    Last Post: 05-15-2011, 09:28 AM
  4. Possible sprocket???
    By Daltoncoody in forum Technical Help
    Last Post: 04-30-2011, 11:15 AM
  5. 13t sprocket
    Last Post: 02-18-2011, 04:52 PM
2002 tw 200 52 tooth
