Front tire removel pointers
Results 1 to 6 of 6
    Member brent morley's Avatar
    Feb 2012
    Dayton Tenn.
    57
    Hey guys I just ordered a new front tire. Can anyone give me some pointers. Thanks...
    I got granny gear haha...
    Member dutchbat's Avatar
    Dec 2012
    Holland
    46
    if the old won't come of with tire irons don't force it.. and just cut the tire open.. a broken or chiped rim will cost you a lot more over time than a bad tire..
    what tire did you buy?
    Member Oldad's Avatar
    Apr 2013
    Shawnee National Forest (Harrisburg), IL
    85
    Breaking the bead of the old tire is the hardest part of the job. To do so I'd first remove the brake disk to insure it is not damaged. Place wooden blocks, 6x6 or several 2x4's stacked on a hard surface at three locations around the wheel, so that they will support the wheel at the rim and the hub is not touching the ground. Stand on the wheel at the rim so your feet depress the side wall of the tire. Near one of your feet place the end of a short (about two feet long) piece of 2x4 on the sidewall right at the edge of the wheel rim. With a 3 pound or larger hammer, strike the end of the 2x4 as hard as you can to force the bead off the rim. It may take a couple of tries, but this method has worked for me.
    After that, change out the tires just like you would on your bicycle, except you may want to use something to keep the tire irons from scratching your rims.
    6,955
    Do it as this guy does. It is simple.
    http://www.mxguy.com/motorcycle-main...eo_05-31-2008/
    Feb 2012
    Dayton Tenn.
    57
    Quote Originally Posted by Tbot View Post
    shinko 244 should be here in a day or two
    Apr 2013
    Central Iowa, USA
    310
    My only advice is to use three, rather than two tire spoons. And if you're bleeding and cussing, you're doing it wrong. Change up your method if that happens
    As far as putting tires back on, I use a lot of baby powder inside the tire with the tube and I use dawn dish soap around the bead or windex.
    Be mindful of your innertube. They're easy to pinch and put holes into.
    Changing a tire right still takes a bit of effort, but a 90 pound girl could do it. So just remember that if things aren't working right, adjust your method. That video posted above is really good.
    1993 TW200
  1. Front tire choices
    By atleastbehandy in forum Sticky threads
    Last Post: 08-06-2019, 05:59 PM
  2. Break-in pointers
    By DonBenito in forum General Discussion
    Last Post: 06-04-2012, 10:09 AM
  3. 160 front tire
    By Mr. BigWheel in forum Performance and Customization
    Last Post: 04-28-2012, 02:50 AM
  4. Bigger front tire?
    By movingtarget in forum Performance and Customization
    Last Post: 10-09-2010, 01:33 PM
  5. Fat Front Tire
    By Jerrcik in forum Performance and Customization
    Last Post: 08-17-2010, 07:31 AM
trailway tire
