Bent Wheel
Results 1 to 4 of 4
Thread: Bent Wheel
    Member canadainshiver's Avatar
    Oct 2011
    New Brunswick, Canada
    77
    Any one have any experience or thoughts?
    Is this wheel still good as-is? Fixable? Scrap metal?
    Came off a bike I purchased non-working that I am currently rebuilding (see tag line). No air leak.
    1991 TW200 Hidden Content
    Mel
    Mel is offline
    Senior Member Mel's Avatar
    Jan 2013
    San Luis Obispo, Calif.
    1,174
    This wheel can be straightened with the proper tools. It must be press straightened, with NO heat, NO hammers.
    May 2013
    Groton, NY
    2,663
    My link
    I've used a deadblow hammer on steel car rims and ATV rims before and worked out pretty good. It won't be perfect, but if you're careful, you can get it real close.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Aug 2011
    Cayce, SC
    3,109
    As others have said, it is fixable. Mallets do wonders. Its how metal was shaped for hundreds of years and still works today. Should take you all of 15 minutes to do it right. By the looks of all that rust, you have bigger problems to worry about.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
  1. Easiest way to get this 1994 TW200 going (bent valve)
    By JTpowersports in forum Technical Help
    Last Post: 06-03-2013, 01:10 PM
  2. Bent Forks?
    Last Post: 09-25-2012, 02:08 PM
  3. Bent Shfter Lever..
    By bookm in forum General Discussion
    Last Post: 06-15-2012, 02:00 PM
  4. Bent frame swap old to new
    By MxRacer69 in forum General Discussion
    Last Post: 03-13-2011, 11:01 AM
  5. bent frame?
    By crossent in forum Technical Help
    Last Post: 10-12-2010, 11:22 AM
straitening tw200 wheel
