Lean surge fix at dealership or diy?
Results 1 to 9 of 9
    Member eli's Avatar
    May 2013
    Florida
    41
    I have what feels like a surging at part throttle, while cruising or during slight acceleration. From the forum descriptions, I think I do indeed have the lean surge. I have read qwerty's carb tuning post. I saw the part about adding washers to the needle to make the lean surge go away. Bike is 2013, with 115 miles on it, in north Florida. I have modified nothing.
    Two questions. First, in qwerty's post it appears that he induces a lean surge, then fixes it with washers under the needle... Would that also be a good fix for a surge that is just happening on its own?
    Secondly, my bike is of course still under warranty. Opinions on whether or not the dealer service dept will successfully fix my issue, or should I just tackle it myself?
    Other than this surging, which I really hate, I am absolutely loving this bike. Here's my first milestone with it...
    Jun 2011
    Dothan, AL
    1,715
    Since it is still under warranty I would start there. Have the dealer take a crack at it first. Should they not take care of it then have a go at it yourself.
    2005 TW200 (SOLD)
    2013 DR650
    May 2013
    Groton, NY
    2,663
    If got a 2013 and mine did the same thing, I added about .050" of shim washers under the needle clip. It runs great now. Another thing I noticed is that an excessively loose chain will magnify the surge.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Member eli's Avatar
    May 2013
    Florida
    41
    Thanks for the replies guys. The dealership was familiar with this condition, and said it was against the law for them to fix this. They said if I brought it to them for my first service they'd do it for me for free.
    I think I'll be handling this myself.
    Apr 2011
    Martinsville Indiana
    2,089
    They are just taking off the brass plug on the bottom of the carb and adjusting "richining up" the idle mixture screw. Thats what needs to be done and a shim sure wouldnt hurt either. You have to love the EPA nuts.
    Member beefcake morris's Avatar
    Dec 2012
    Jacksonville, Fl
    99
    What part of North Fl. are you in? I had the same exact problem, plus some when I bought my 2013 in St. Augustine.
    I ended up with 5 shims and a 130 main jet. I almost think I need to go to a 132.5 jet sometimes, but it certainly runs better.
    "I am simply a guy trying to master a very simple machine with very complex dynamics"
    MSF Rider coach
    Jun 2011
    Dothan, AL
    1,715
    What part of N Florida? I have some shims and a 130 main jet you can have.
    2005 TW200 (SOLD)
    2013 DR650
    Member eli's Avatar
    May 2013
    Florida
    41
    I'm in Perry, about 50 miles or so southeast of Tallahassee.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    I'd go with a larger main jet,shim(s) under the needle and turn out the pilot screw 2.5 turn's as stated above.The dealer know's they'd be commiting an EPA (felony) by do the work...do it yourseld,it's not hard to do at all....plus there are plenty of folks here (you have folks who want to give you parts!....WOW)to assist you!. Welcome.
  1. Is it a lean surge?
    By Guitarman in forum Technical Help
    Last Post: 05-20-2014, 05:21 AM
  2. Local dealership trying to jerk me around?
    By smzayne in forum General Discussion
    Last Post: 05-02-2013, 08:04 PM
  3. Local dealership trying to jerk me around?
    Last Post: 05-02-2013, 03:11 AM
  4. Lean Carb. - Need Help
    By DBuck42 in forum Technical Help
    Last Post: 10-26-2011, 06:06 AM
  5. new-went to dealership today
    By TrevorW in forum General Discussion
    Last Post: 10-07-2010, 09:41 AM
yamaha roadstar surging cruising
