Lift the height at the back on my Tw 125
Results 1 to 2 of 2
    Junior Member Elvdaking's Avatar
    May 2013
    England UK
    4
    Just wanted to know if I can raise the back up a bit but without buying a new shock? I heard about a clip that can be moved but how do I disassemble the shock and spring and how much height will I gain? It feels ok at the moment but I'm quite tall and would love it to be a little higher. Also my bike is a 2004 125cc but I'm sure its the same shock.
    Thanks Matt
    Member craigerk's Avatar
    May 2011
    54
    The clip you are talking about only adjusts the stiffness a bit, the height is the height. It might add a tad of lift when sitting on it cause the spring is stiffer, but no curb height. Only way to change height is to swap the shock, I did the blaster but its obnoxiously high. The banshee will add an inch or so I believe from the rear shock post in the performer forum. I bought a vtr1000 shock to put in (came in today so it'll be in tomorrow) and from what I read on a post in the forum will add maybe inch and a half plus spring is stiffer.
  1. What's your height and weight?
    By siggi101 in forum General Discussion
    Last Post: 12-01-2012, 09:55 PM
  2. Tdub up on the lift for chain and sprockets.
    By qwerty in forum Technical Help
    Last Post: 08-30-2011, 03:19 PM
  3. Cheap hydraulic motorcycle lift
    By dhoenisch in forum General Discussion
    Last Post: 03-07-2011, 08:13 PM
  4. TW200 on a lift/stand?
    By RynnStorm in forum Technical Help
    Last Post: 02-18-2011, 02:57 PM
  5. Ride height
    By rickm in forum Technical Help
    Last Post: 01-29-2011, 03:36 PM
how to lift your 125cc
how to lift your hieght on a 125
tw200 lifting rear
tw200 with vtr1000 shock
