$2.00 well spent
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By old white truck
Thread: $2.00 well spent
    Sep 2012
    Northwestern Oregon
    1,092
    I usually loosen up my turn signal stalks when I am going to be trail riding in the hope that they will be less likely to break when the bike decides to take a dirt nap.
    Getting a 17mm wrench or a Crescent on the stalk nut can be a pain because of the way the nut is set into the well in the fender plastic. I got to wondering about an easier way to adjust the nut. It seemed like a flare nut wrench might not fit and an offset box end would fit but would require removing the wires first.
    The next day I was at the nearby mom & pop tool store in town. I found the perfect wrench in the half-off bin of miscellaneous tools. For a grand total of $2 I got a Facom (made in France) 16 and 17mm offset ring wrench. I got the grinder out and cut a slot in the 17mm ring and now it works great! I think I’ll cut the 16mm end off and put the wrench in my travel tool bag.
    Member Lonesome Dave's Avatar
    Feb 2013
    Black Hills, South Dakota
    41
    Thats a great idea, thanks for sharing.
    Senior Member RainWillFall's Avatar
    Jan 2013
    Niagara ON.CA
    127
    Can I borrow it! I'll be on the look out for one of those!
    '09 TW200 - Black Jimbo Shield - Custom Oversize Foot Pegs - Tusk T-10 ATV Sport Bend Bars - Hammer Black Cycle Rack - Tool Tube (Muffler Style Mount) - 15/50 Sprocket - HID Headlight - Custom Mount Ducati Monster LED Tail Light - LED Turn Signals - Eagle Eye Running Lights - OURY Road Grips - Shinko 700 Trailmaster Front Tire.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Good thinking, I may have to add one to my kit.
    May 2013
    Groton, NY
    2,663
    My link
    Tubing wrenches work good also.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member patrick007's Avatar
    Jan 2013
    Red Deer, Alberta Canada
    112
    Very good idea props to you !!
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    Good thinking.
    Senior Member mattmus4357's Avatar
    Oct 2012
    NW Arkansas
    250
    Just ordered mine off Amazon for $6.47 shipped. Not quiet as good as your $2 deal but much better than the $15 Craftsman version at Sears.
    Sep 2012
    Northwestern Oregon
    1,092
    Quote Originally Posted by r80rt View Post
    r80rt, I went back again and the store had another one. It was a no-name Chinese brand instead of a Facom but it is the same design. If you want it, PM me your address and I will send it to you for free just cause your avatar is so darn goofy. I can also slot the box end and cut the other end off it you want?
  1. I might have spent too much time on here..
    By PalmStateCrawler in forum General Discussion
    Last Post: 12-09-2012, 11:06 PM
