Noob question- steering lock
Results 1 to 5 of 5
    Member decade03's Avatar
    Sep 2012
    NC
    34
    I'm trying to put my TW in steering lock mode via the ignition. The manuel says that from the OFF position, press in the key, release it, and you should be able to turn it to LOCK. When I try this, it only goes halfway before I can't turn the key any further and I can't remove it from that position. If it's all the way on the lock position, I should be able to remove it. Any solutions to this?
    2009 TW200, first time rider!
    Nov 2011
    norcal nutjob
    3,329
    make sure you cock the handlebars all the way to the left, if they aren't you can't lock it.
    Sep 2012
    NC
    34
    Quote Originally Posted by joe band View Post
    YEP, that did it. Thanks man!
    Jul 2012
    Wet-ern Washington
    1,411
    All of the way to the right works too.
    - Leisure Time Larry -
    Sep 2012
    NC
    34
    Quote Originally Posted by lrppcer View Post
    Indeed boss!
  1. Steering lock problem
    By rex in forum Technical Help
    Last Post: 03-15-2017, 12:08 PM
  2. 2002 Steering Lock
    By pizzadude in forum Technical Help
    Last Post: 09-30-2012, 11:20 AM
  3. Question about steering
    Last Post: 10-03-2011, 03:25 PM
  4. Does my '87 T-Dub have a steering lock?
    By rex in forum General Discussion
    Last Post: 07-31-2011, 09:38 PM
  5. Steering lock
    By wayne in forum Technical Help
    Last Post: 07-12-2011, 11:29 AM
2009 yamaha tw200 steering lock on the steering shaft
yamaha tw200 lock
