what tool am i missing?
Results 1 to 9 of 9
    Member dutchbat's Avatar
    Dec 2012
    Holland
    46
    So,
    i was bussy with my forks and bumpt into a problem.. when removing the jokes i ran into these nuts (see image) and figured wrongly when i tried to open it with a normal plumbers wrench.. so here's the question: what kind of tool and what size do I need to buy for this f****** nut, or, is there another way of opening this thing without using a special tool?
    any help would be awesome!
    thanks
    Mar 2011
    Gobles, michigan
    1,826
    I'd say a hooked spanner wrench........ The thing is they come in so many different sizes.. Good luck... I use them on adjusting shocks on snowmobiles. OMM.
    Sep 2012
    Northwestern Oregon
    1,092
    Ideally you need a ring nut wrench. Of course Yamaha makes a special one for a special price (#YU-33975). However, you can also loosen it with a hammer and a flat head screwdriver and then take it the rest of the way off with a pair of Channel Lock pliers.
    Ephrata, WA
    1,125
    I searched high and low for the "special tool". I couldn't find it stocked anywhere but they could be ordered. I tried a couple shock adjusting wrenches and they wouldn't fit. I also took a huge socket and welded on some square stock to turn it. Turns out, an old flat blade screw driver and a hammer worked wonderfully. You'll scar the ring nut up just a little, but you won't hurt anything and you can't really see it when done. I asked around at some of the local shops and they say they use the screw driver/hammer method. It shouldn't be on there all that tight.
    I like to use the correct tool for the job. When I was told to use the hammer/screw driver method I was skeptical. A couple light taps and the nut was off.
    1990 TW200
    7,013
    I did what Rainman did only I used a round flat tipped punch. Same idea.
    Apr 2013
    Central Iowa, USA
    310
    Some variant of these is always better than a flathead screwdriver.
    1993 TW200
    Mar 2011
    Gobles, michigan
    1,826
    Quote Originally Posted by silverhead View Post
    The top two are what I was thinking... Only the ones I use have a pivoting joint for a more adjustable range.. OMM.
    Ephrata, WA
    1,125
    If you guys find a spanner wrench that fits (other than the Yamaha one) please let us know. I tried a Bike Master one and it was close but didn't work.
    1990 TW200
    Dec 2012
    Holland
    46
    screwdriver and hammer method worked like a charm (didn't damage anything)! thanks guys..
  1. Missing head gasket?
    By PalmStateCrawler in forum Off-Topic
    Last Post: 09-18-2012, 11:51 PM
  2. Missing some specs.
    By arbolmano in forum Technical Help
    Last Post: 04-04-2012, 08:33 PM
  3. If your tow strap suddenly goes missing.......
    By lizrdbrth in forum Off-Topic
    Last Post: 03-23-2012, 10:49 PM
  4. Missing main nozzle??
    By dirkK in forum Technical Help
    Last Post: 03-20-2012, 12:59 AM
  5. Missing bolts?
    Last Post: 09-06-2010, 03:19 PM
yamaha spanner wrench yu33975
yu-33975
