electrical help, Push Starts only
Results 1 to 10 of 10
    Senior Member iowatdub's Avatar
    Aug 2012
    Iowa
    130
    My TW is not showing any signs of electrical power when I turn on the key. It push starts fine. Battery is at 13.5 V or so. I had been running many miles at high RPMS, wondering if it could have overcharged the system. I checked the 20 AMP Main fuse, Its fine. I have checked the obvious I think, Messed with sidestand, etc. Any ideas. I will be going to the manual but wondered if there are any common issues with this?
    2008 TDUB
    May 2013
    Groton, NY
    2,663
    If you have no headlight, tail lights, etc.,check battery connections, see it they are clean and tight.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Aug 2012
    Iowa
    130
    brand new battery this spring too! I checked the connections
    2008 TDUB
    Aug 2012
    Iowa
    130
    Ok. checking voltage with key off....14.5 volts, with key on, zero?
    is my switch bad?
    2008 TDUB
    6,959
    Get a kick starter so if problems like this arise when you are riding on loose soil you will still be able to start it.
    Senior Member LittleCowTW's Avatar
    Portland, OR
    152
    Do you have lights? switch is probably fine. You could jumper it out to be sure or check for continuity with a multimeter. If your lights work I would start testing starting components. Push button first then starter relay etc.
    Persistence is the better part of genius.
    Junior Member Tdub hooligan's Avatar
    May 2013
    St Louis, MO
    9
    I've bought a lot of batteries in my life and I've had at least three that were faulty out of the box. You might want to have it checked.
    If some is good and more is better, then too much is just enough.
    May 2013
    Groton, NY
    2,663
    Is that 14.5 volts at the battery? If it drops to zero at the battery with switch on and it's not blowing the main fuse, the battery is bad.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Aug 2012
    Iowa
    130
    I think my voltmeter is fried. checked the battery on my buddies Fluke tester and got 10.5V . Taking my battery in to get it tested and replaced. Just got it this spring, It is a bikemasters gel cell and has a 2 year warranty. Sure hope I can find the receipt. Im still baffled by why it went out. I rode just at 400 miles over the weekend and it should have charged it fine. I still wonder if my charging system is over charging. I am on I think my 4th battery in as many years. I will give a little ride report in another Topic. Had a good ride and Im sure glad the battery didn't give out on the "deer path trail" that I checked out after I set up camp.
    2008 TDUB
    Aug 2012
    Iowa
    130
    Shop said the Battery is fried. (One cell dead) Good lesson for going to the basics first I guess. I just bought it in March!! luckily it has a 2 year warranty
    2008 TDUB
  1. Starts, Then Won't Stay Running (Sort Of)
    By Oldad in forum Technical Help
    Last Post: 09-27-2016, 02:36 PM
  2. Got Shirts? - The countdown starts
    By Rohnsman in forum General Discussion
    Last Post: 10-08-2012, 08:11 PM
  3. Push starting a TW
    By PalmStateCrawler in forum General Discussion
    Last Post: 10-07-2011, 07:51 PM
  4. Tw200 starts up but then WIde open
    By Daltoncoody in forum Technical Help
    Last Post: 04-14-2011, 09:27 AM
  5. Second gear starts
    By Hobopoet in forum Performance and Customization
    Last Post: 03-19-2011, 04:43 PM
yamaha tw 200 no electric power
