Easiest way to get this 1994 TW200 going (bent valve)
Results 1 to 3 of 3
    Junior Member JTpowersports's Avatar
    Jun 2013
    OK I have a TW200 with a bent valve. I know a valves cheap and everything but I also have a TTR225 engine and TTR230 engine in my shop. The 230 engines a runner but I can visibly see the countershaft is too short. I have a 225 engine that had a motor mount bolt seized in it, when hit with an impact to loosen it I broke the front motor mount clean off the engine. This engine could be robbed for parts. I've read that the 225 top end can go on but the cases need bored, that's more work than changing a valve. However it didn't mention if I could just stick this 225 head straight on to the TW200 cylinder?
    Anyone know?
    Jun 2013
    Tennessee
    1,285
    I honestly can't be sure. I would say you'll get an answer soon but I would go all or nothing on it. Either replace the valve or bore the cases and go bigger. I have a feeling you can make the swap with the stuff you've got on hand, but standby for better info on that one.
  1. 1988 and 1994 TW200's for sale
    By flyinlow78 in forum TW200 Classifieds
    Last Post: 07-04-2013, 08:11 AM
  2. 1994 TW200 Rebuild
    By P.ortega in forum Performance and Customization
    Last Post: 06-20-2013, 08:27 AM
  3. TW200 1994 Decals wanted
    By Return of the Cafe Racers in forum TW200 Classifieds
    Last Post: 05-05-2013, 05:38 AM
  4. 1994 TW200 - New England
    By Point37 in forum TW200 Classifieds
    Last Post: 01-23-2012, 10:59 PM
  5. 1994 TW200 in Austin
    By JarrodWeaver in forum TW200 Classifieds
    Last Post: 02-07-2011, 06:00 PM
how to tell if i have a bent valve on a ttr225
ttr 225 valves may be bent
tw 200 how do you diagnose broke vaulve
