12V Power Outlet
Results 1 to 4 of 4
    Senior Member Swamp's Avatar
    Apr 2013
    Michigan Territory
    108
    I'm installing a 12V power outlet on my bike, and was wondering what amp fuse I should use? This will be for powering my GPS, and possibly charging a cell phone!
    Swamp
    2006 TW200
    Apr 2013
    Central Iowa, USA
    310
    Typically in a car the cigarette lighter plug is fused at 5 or 10 amps, but you'll be good with 0.5 amp since you're only powering electronic goodies. Maybe you'd have to bump up if you ever wanted to plug in an electric vest or something, but for the time being I'd use half an amp just to be safe.
    1993 TW200
    Aug 2011
    Cayce, SC
    3,109
    I just put 10s in all mine. It should charge/run anything you put on it that the battery can handle. It mainly protects stuff from a short or something like that.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    May 2013
    Groton, NY
    2,663
    My link
    My link
    Here is a chart and some info that should help you to pick wire size and fuse size.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
  1. Power outlet
    By r80rt in forum Performance and Customization
    Last Post: 04-21-2013, 06:39 PM
  2. 12 volt outlet
    By pbfirefighter22 in forum Performance and Customization
    Last Post: 10-09-2012, 09:17 AM
  3. Would like a little more power
    By Mizzoolian in forum Performance and Customization
    Last Post: 09-13-2012, 10:32 PM
  4. I GOT THE POWER...
    By Retrofit in forum Performance and Customization
    Last Post: 08-28-2012, 02:14 PM
  5. No power
    By bschauffler in forum Technical Help
    Last Post: 08-27-2010, 09:07 AM
