gas everywhere
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By RockyTFS
Thread: gas everywhere
    Member belterskelter's Avatar
    Rossland bc
    37
    So the bike seems to have a leaky petcock, I am getting a new one, and if i switch to reserve gas it seems to pour out the overflow, Any way the bike stinks of gas and hoping i don't catch fire, what to do with the overflow?
    The bike seems to run ok, I seem to be replacing parts on this new to me bike once a week. when riding it seems ok gas is going where is should but sitting over night it leaks with gas off or on.
    two wheels for life!
    Senior Member Omega Man's Avatar
    Jan 2012
    Taxachusetts
    173
    Quote Originally Posted by belterskelter View Post
    I'm not sure where you are referring to as "the overflow". If it's down at the bottom of the carb, it usually means the float is stuck. I don't think I've seen a petcock go bad. In a recent service of my '94, I changed back to the stock tank- it had a Clarke on it- so I had to swap the petcock back over. There isn't much to the petcock itself. You didn't mention the year of your TW, but age does sometimes wear on things. OM
    "It's more fun going fast on a slow bike than going slow on a fast bike" UK
    1994 TW200, 2009 F800GS loaded,
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    So the bike seems to have a leaky petcock, I am getting a new one, and if i switch to reserve gas it seems to pour out the overflow,...it seems ok gas is going where is should but sitting over night it leaks with gas off or on.
    Might be more than one problem.
    Remove the fuel line from the carb and with the petcock off, see if any gas comes out of the line.
    If no gas comes out, the petcock is OK.
    The leak then is from a stuck float, or crud holding open the float valve.
    Or...
    the o-ring on the float valve is bad, and fuel is leaking around the float valve even when it is closed.
    If that's the problem, you will need to remove the float:
    https://tw200forum.com/index.php?/top...buretor-float/
    Jb
    Apr 2013
    Central Iowa, USA
    310
    I've had petcocks leak on me on nearly every bike I have owned. I usually spray them with silicone spray which penetrates past the metal parts down into the rubber gasket that seals things from leaking fuel and helps soften it up a bit. That's how I 'maintain' this gasket. Sometimes if they leak, they leak and the only fix is to replace the gasket.
    New petcocks are cheap for this bike though, so I'd happily pay the 17.50 for a new one. (OEM, not generic.)
    http://www.ebay.com/itm/NEW-GENUINE-...210f01&vxp=mtr
    What is probably going on here is that the rubber gasket that looks like a smiley face which lives behing the ON OFF RESERVE lever has microscopic cracks in it due to age OR it has deformations in the rubber because your petcock sat, unused, in either the ON or OFF position for several years when the previous owner did not ride it. I have had to replace these smiley face gasket in a lot of motorcycles. They're referred to as 'whizzer gaskets' and they go bad with age OR if people use gasoline with ethanol fuel in it. Ethanol fuel can ruin gaskets like this in a short amount of time.
    My vote is to just purchase a new petcock or purchase the rubber gasket itself.
    The yamaha dealer will ding you for $6.50
    VALVE PACKING
    3AC-24523-00-00
    That is the part number for a 2010 bike.
    VALVE PACKING
    3AC-24523-00-00 (replaces 3AJ-24523-00-00)
    ^this is for a 1995 bike. So it looks like the valve is universal to all TW200 petcocks.
    1993 TW200
    Rossland bc
    37
    the bike is a 1990 so it is a bit old and things have been happening with it,eg bad riding skills =crashing, and the stator dies, now gas leaking, it will be a new bike by the time I am done!! I will check about the float valve
    Thanks for the help every one!
    R
    Member 2Oceans's Avatar
    Jun 2015
    Johannesburg, South Africa
    30
    After coming back from my first offroad trip on the tdub, smelled petrol, and also found my carb to be dripping.
    I am quite keen to pull the carb of and give it an overhaul. So now it seems I have an excuse.
    I know there is a good tutorial on the forum which I will go through. I would also like to replace the missing run off pipe. Can anyone post a pic of what it's supposed to look like, and what size/length it is?
    Any other advice before getting my hands dirty with this?
    Tks
    Hailey, ID
    3,377
    .....I will check about the float valve
    Since very few owners ever get this far inside the carb (once you read the instructions to remove the float you will know why), it is important to note that that little screen on top of the float valve can get clogged by crap that somehow gets by the petcock filter, and produces totally different symptoms, namely bogging at full throttle in higher gears.....so be sure you get it really clean under a bright light with high pressure air. It is a little known fact that SOME crap that clogs filters is nearly invisible. Please don't ask me how I know this....it was a near death experience involving raw fiberglass.
    2Oceans likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
cork gasket to replace petcock smiley face
how to remove the needle valve seat yamaha 3aj
sticking float valve
