Grease nipple size?
Results 1 to 9 of 9
    Junior Member rtf's Avatar
    May 2013
    10
    Hi Guys,
    Lubricating using a new gun broke one of the grease nipples - is M6 our replacement size? (and does the stub come out easily with a socket-wrench)
    I see a few options here for the grease nipple -
    http://www.amazon.com/s/ref=nb_sb_no...+grease+nipple
    Also, what's our spark plug wrench size?
    Thanks -
    RTF.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Not by my manual nor the bike,but,the grease nipple should unscrew (there should be a nut at the base of the nipple). Should be able to order one online or down at the local MC shop?.....but, I know,It'll be 2x the price of one from a hardware store.this doesn't really answer your question.You could also take the other one out for comparison and take it to a hardware store etc.
    May 2013
    10
    HI Frog - I truly truly wish a mc h/w store was around here in Boston ... No suck luck! I tried unscrewing it with a socket but given the tight space it didn't work out ...probably going to get a small t driver and give it another shot. Any issues if I leave it just like that ? Any alternatives to lube the suspension any other way?
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    If you can get an open end 8mm wrench on it, it'll come out pretty easy. Any auto parts store should have one in stock. Spark plug socket is 18mm.
    May 2013
    10
    thanks rt, will give it another try. Love the avatar!
    Jun 2011
    SW, Ohio
    2,518
    If your having spacial issues.....remove the rear wheel....also what r80rt said.Maybe lightly spray some PB blaster around the nut first....let it sit for alittle while...20 minutes or so,then retry?.
    May 2013
    10
    Thats a good idea to apply solvent first ...will give it a shot later this week, been raining like crazy for a couple of days, and bike's sitting covered
    Senior Member Omega Man's Avatar
    Jan 2012
    Taxachusetts
    173
    A square style E-Z out works well. If it's had any grease at all, it shouldn't be frozen in due to the grease. OM
    "It's more fun going fast on a slow bike than going slow on a fast bike" UK
    1994 TW200, 2009 F800GS loaded,
    May 2013
    10
    Hi Guys -
    In another episode of Me-Against-Me - I managed to strip the screw - Now part of the screw is stuck inside the threaded base. So couple of questions -
    1. Are there Any small tools which would let me take it out?
    2. If I let it be the way it is, any issues? can put a couple of drops of oil on top of it every month - would that lube the suspension to some degree?
    ON a positive note, I can confirm now that it's an 8mm screw that the grease nipple is based on
  1. Needle bearings and Moly grease
    By frog13 in forum Off-Topic
    Last Post: 06-11-2013, 05:53 PM
  2. Brake fluid and lithium grease
    By Dwight in forum Technical Help
    Last Post: 01-21-2013, 08:50 PM
  3. Carb nipple Identification help
    By Tonto90 in forum Technical Help
    Last Post: 01-10-2013, 09:24 PM
  4. Grease in Magneto (?)
    By msmiller in forum Technical Help
    Last Post: 09-07-2012, 08:13 PM
  5. Swingarm nipple snapped off.
    By turborob in forum Technical Help
    Last Post: 07-31-2010, 07:22 AM
greasenipplesize
how to grease tw200
lithium grease
