Seat Bolt replacements
Results 1 to 7 of 7
    Junior Member Akari.Blue's Avatar
    Sep 2010
    Poulsbo, WA
    18
    Since I knocked the bike over replacing the chain and sprockets, I needed to pull the seat off to check the battery. In the process, I sheared off the head of one of the seat bolts. Hardly any torque on the wrench and it just snapped clean! How annoying. I can take the seat strap off, which I meant to do anyway, and use one of those bolts instead of the sheared one. But there has to be a better way to hold the seat on.
    I vaguely remember people on the old forum talking about alternatives to the seat bolts, ones that wouldn't require wrenches. I'd be interested to know what types of replacements are holding up well over time and lots of riding, if anyone would care to share.
    Has anyone tried putting just headless screws in there as "posts" and used a strap over the cyclerack frame to hold the seat in place?
    Akari
    1996 TW200 Edmonton, AB
    590
    One of mine was sheared off when I got it, that seat fixing idea was not one of Yamaha's best inventions.
    Lots of people seem to be using headless bolts with holes drilled for a clip.
    I ended up using this, just extending the bolt head enough I can turn it by hand. Has been working fine hand tight, just one on one side. Might put a little copper slip on the threads.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Had to chuckle. Here we sometimes spend so much time thinking of a design that NASA may have come up with. Here you just screw on a few oversized nuts as spacers and a grip surface and lockem in place to call it good.... It looks like it will work GREAT, and likely gave you back 55 minutes of prime-time living as some of the ideas we have come up with requires lots of hardware store browse time.......... Can't knock a simple idea that works......... Thanks, Gerry
    Take care my Friend.........
    1993 TW200 in Meridian, Idaho
    1,533
    Read this thread...
    Senior Member abyssdncr's Avatar
    Sep 2010
    Wichita, KS
    164
    Quote Originally Posted by Truelight View Post
    Read this thread...
    I went with the hitch pin route. Just center punch & drill a few thou over the diameter of the hitch pin you pick up. I also added simple keyrings to the hitch pins so they're easy to pull out. Next time I'm at the hardware store I'll get some wire/braided cable to attach to each pin with the keyring in the middle. Grab the keyring & pull left, then right, voila!
    With the hole already drilled, you can use a washer to simulate the seat tab to make sure they're snug to the frame. Just keep adding half turns to the stud until the clearance is tight, then double check fitment with the washer, remove and reinstall with blue loctite. This way you're assured they won't rattle out and if you NEED to remove them again, just insert the hitch pin for a handle.
    Couldn't be happier with this cheap & simple little mod!
    2006 TW200, LED tail & turn signals, Clarke XT350 tank, hybrid YZ80 forks, CycleRacks rear rack, Ricochet bash plate, TTR225 header, eBay pegs, MSR high ATV bars, Tusk bar risers, Tusk handguards & deflectors, Tusk KX250 stainless brake line, XT225 speedo cable, 14/47 sprockets, Mule-pin seat latches, 130 main, 0.035" shimmed needle, TW34/M6006 meats.
    Sep 2010
    Poulsbo, WA
    18
    Read this thread...
    Thanks for the link, Truelight I didn't think to look in that sub-forum before posting.
    I had the idea of using a hitch pin through a headless bolt, but haven't because of the possibility of the pins getting knocked out when riding offroad. Plus my housemate's forbidden me from drilling or otherwise using any kind of power tools on metal without supervision, so I'm rather limited in what I can do.. *amused grin*
    PJungnitsch, I like your idea of the longer bolt with multiple nuts. Very neat. I've probably got suitable things to make those already. I think I'll try that and see if I can avoid ripping any more bolts apart on my poor bike.
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    I bought 2 bolts with counter sink heads, slid a 5/16" wingnut down to the head welded it there, then welded a washer on the bolt creating about the same length as stock bolt, then a piece of nylon strig attached to the bolt and swing arm so they cannot be lost.
  1. Engine bolt set
    By Tirebiter in forum Technical Help
    Last Post: 02-16-2013, 03:08 AM
  2. Side cover screw replacements
    Last Post: 12-01-2012, 09:35 AM
  3. Anyone ever Helicoil oil pan bolt?
    By Jemo in forum Technical Help
    Last Post: 06-16-2012, 08:00 PM
  4. Best way to Recover a seat? My seat is Teal :(
    By panamacolin in forum Technical Help
    Last Post: 07-17-2011, 05:51 PM
  5. Passenger Peg Bolt
    By assquatch20 in forum Technical Help
    Last Post: 09-03-2010, 07:54 PM
how to take seat off a tw200
seat bolt
seat bolts
tw200 seat bolt
tw200 seat bolt size
tw200 seat bolt size forum
tw200 seat bolts
tw200 seat bolts photo
tw200 t-bolt for seat
what size seat screw tw200
yamaha tw200 seat bolt
yamaha tw200 seat bolts
