Tank removal
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Deldog
Thread: Tank removal
    Junior Member Deldog's Avatar
    May 2013
    21
    Hello. I am planning to have my tank sandblasted and need some advice. I saw this helpful thread below detailing how to remove a TW tank:
    "Piece of cake. All you need is a 10mm socket. Remove seat by removing two bolts under it, cut off gas from tank, remove gas hose from tank petcock, remove bolt from base of tank and slide tank backwards....... done."
    This is good advice, but before I dig in, I have a few questions:
    1. Should I drain the tank first? If so, is the best way just to start the bike and let it run out?
    2. "Cut off gas from tank" ... Does this mean anything more than turning the petcock to the off position?
    3. "Remove gas hose from tank petcock" ... How is this attached? Will I need a special part to reattach?
    Thanks for your help! ... Deldog
    p.s. Gorgeous day here in southern Delaware. I'd rather be out riding ...
    LuvNot likes this.
    Senior Member Omega Man's Avatar
    Jan 2012
    Taxachusetts
    173
    Quote Originally Posted by Deldog View Post
    It's really easy....no need to over-think it
    You don't have to drain the tank. It wobbles with the sloshing gas once it's off- no big deal.
    Petcock off will stop the fuel flow.
    The gas line goes on a "barbed" fitting on the petcock. Sometimes there is a small clamp- self explanatory really. Once the clamp is off, you may have to gently rotate the hose before you slide it off- again no big deal.
    You mention sandblasting, while it might mean actually sand, I'd be careful. Glass bead blast or the new "soda blast" or walnut shells etc. will be less traumatic to the thin steel of the tank. I'd also give it a real good interior clean when your done- 1/4 full of kerosene and a good shaking would probably do it.
    OM
    "It's more fun going fast on a slow bike than going slow on a fast bike" UK
    1994 TW200, 2009 F800GS loaded,
    Lower Rio Grande, New Mexico
    1,702
    BTW, If your gas leaks after you disconnect the hose, I'd rebuild or replace the petcock. This operation is when many of us find we have a bad petcock and have avoided problems only by religiously shuting off the petcock upon dismount. Oh,,, you don't turn off the petcock, then you are one of the luck ones that has not had a bad petcock seal (Yet). Cheers, and yes you are on the right track. Don't sweat the small stuff. Tom
    Central New Mexico
    May 2012
    Tucson, AZ
    976
    I don't disagree with anything Omegaman said, but I will offer this step by step.
    1. Set the fuel petcock to "OFF"
    2. Remove the seat.
    a. 2 bolts and a suction cup. See Owner's Manual.
    3. Disconnect the fuel line at the carburetor. NOTE: Make sure the petcock is in the "OFF" position before executing this step.
    a. Open the clamp with pliers.
    b. Slide the clamp away from the barbed fitting on the carburetor.
    c. Twist and pull the fuel line free of the carburetor barbed fitting.
    d. Install a small rubber plug or cap to keep debris out of the carburetor male barbed hose fitting.
    4. Remove the TW200 gas tank. See previously referenced tw200forum.com posting.
    5. Drain gasoline into DOT approved receptacle.
    a. Secure full gas tank approximately 3" above DOT approved fuel receptacle opening.
    b. Place carburetor end of fuel line into DOT approved fuel receptacle opening.
    c. Turn fuel petcock to "RES" position.
    d. Allow contents of gas tank to drain into DOT approved fuel receptacle.
    6. Remove cap from gas tank. Set aside.
    7. Remove fuel petcock.
    a. Remove the 2 bolts holding the petcock to the tank.
    b. Place the two bolts, petcock gasket, and the petcock/fuel line assembly into a zip-lock bag.
    c. Set bag holding petcock assembly aside near the gas cap.
    8. Take gas tank to the media blaster.
    BONUS STEP!
    9. Guess which forum member works in government.
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    May 2012
    Tucson, AZ
    976
    Boo! My indents didn't work.
    2012 KLR650
    - Sold
    May 2013
    21
    Amazing, Don Benito. Thanks!
    May 2013
    21
    Thanks, Omega. Appreciate the tips.
  1. Air box removal
    By neimang in forum Performance and Customization
    Last Post: 09-18-2014, 01:17 PM
  2. Camshaft removal
    By fredzaha in forum Technical Help
    Last Post: 06-23-2013, 09:03 PM
  3. Air box removal
    By neimang in forum Technical Help
    Last Post: 06-21-2013, 10:27 AM
  4. decals removal
    By glassyandsunny in forum General Discussion
    Last Post: 05-08-2013, 02:09 PM
  5. Tank Decal Removal?
    By retro in forum Technical Help
    Last Post: 04-04-2011, 03:56 PM
