TW won't start
Results 1 to 10 of 12
Thread: TW won't start
    Junior Member Deldog's Avatar
    May 2013
    21
    Well, my follies are becoming a regular feature here on the technical forum. Really appreciate all the expertise here.
    I did the ultimate in foolishness recently by leaving the ignition on overnight. So, I took out the battery and hooked it up to a "Battery Tender Jr." When it was hooked up, the red light went on, signaling it was doing its job.
    I left that hooked up overnight, then replaced the battery and tried to fire up the TW. Still nothing.
    Found this in another post and am going to try to look into it. Don't know much about it, but ...
    There is also a fuse link on your positive lead coming from your battery that could be blown. When i bought
    mine the guy said the starter doesn't work and he didn't know why. He said it may just need a new battery.
    When i got it home i could tell the battery was brand new so i checked the fuse and that was my problem. Luckily
    it had a spare in the fuse holder.
    Thanks for any input! ... Deldog
    Senior Member immgunn's Avatar
    Sacramento, CA
    172
    I'm not sure you can charge a dead battery with a battery tender. I think they're made to prevent the battery from going dead while not in use. Do you have a voltmeter? If so, check the battery voltage. You can also try jump starting it with jumper cables. Good luck.
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    The fuse is on the right side behind the owner's tool kit, follow the red battery cable to it. I would check that first but I think you will find that is not the issue.
    The stock battery isn't the greatest and when mine died I could not get any charger to recharge it enough to start the bike. They all said they had charged it but a multimeter showed it only had 8 volts not 12. I would bet that your battery is now toast. I got lucky and a local dealership had one in stock that they filled and charged for me so it was ready when I picked it, due to postal regulations most batteries are now shipped empty with a packet of acid mix and you have to fill and charge the battery yourself. If you need a new one try to call around and find a place that has it and will do that for you.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,390
    Take IMMGUNN'S advice.
    Check the voltage of the battery.
    The Deltran Battery Tenders require at least 3 volts for them to begin charging.
    If your battery has less than the required 3 volts, the charger will not do anything at all.
    Hook up another battery in parallel to jump start the engine, or just so the changer senses more than 3 volts.
    Jb
    May 2013
    21
    Thanks much, guys. I forgot to mention that this battery is maybe 3 months old.
    So, I'm going to pick up a voltmeter and see what that says. I used a "Battery Tender Jr." One of the other models, a "Battery Tender Plus," says it will charge a dead battery. It's $70, though. Not sure I want to try that ...
    Well, lesson learned. Hope I can get this fixed and back on the road soon. I just moved, so I have many miles of fresh roads awaiting!
    Senior Member Omega Man's Avatar
    Jan 2012
    Taxachusetts
    173
    I try to be very careful about jumping a small battery (TW) from a large battery (my truck). The same goes for a small battery charger (small batteries), my shop charger on wheels (large batteries). Something you may want to try to get you through is hooking up jumpers between say the TW and your 4 wheel vehicle- but don't try to start anything. Just let them set that way for an hour or so. Then you can hook up the Battery Tender that you have and (hopefully) finish the job.
    All that said, it's always a good idea to have a DMM (digital multimeter)around.
    BTW this is all worse with fuel injection, on my F800, it the computer doesn't "see" 9.2 volts, the battery may as well be missing. Good luck'
    OM
    "It's more fun going fast on a slow bike than going slow on a fast bike" UK
    1994 TW200, 2009 F800GS loaded,
    May 2013
    21
    Thanks, Omega. Here's my plan.
    1. Get a multimeter and check for voltage.
    2. If no voltage, I'll try your trick of hooking up to truck for an hour, then letting the tender take over.
    3. If I do have voltage, then the problem is elsewhere, correct?
    Thank you again for your help. Really appreciate it. ... Deldog
    Jan 2012
    Taxachusetts
    173
    Quote Originally Posted by Deldog View Post
    Yeah, you pretty much have it. If you are going to buy a DMM, I can recommend the Radio Shack 22-813 but any DMM will work.
    A really old trick on an obvious check of a batteries condition is to turn the key on, see the head lamp on, watch what happens when you hit the electric starter button. If the headlamp goes out, it usually means the battery is weak. There is an exception to this test in that sometimes a starter can be so bad it draws too much current and still doesn't start the engine.
    I have a feeling that when you get a charge into the battery, things will be better. It's good to remember that lead acid batteries really don't like being stone dead.
    BTW I just learned that Exide, a US battery maker just filed chapter 11 after losing the Walmart contract- for those interested.
    OM
    May 2013
    21
    10-4, thanks. I'll check back after I find out what's up.
    Apr 2013
    Central Iowa, USA
    310
    I've brought motorcycle batteries back from the dead using a wall wart Battery Tender, so you're fine there. They charge at maybe 1 amp max so it's safe. They're also computer controlled. Once the light is green, the battery should make the TW200 turn over at the starter.
    So is the starter turning or not? I'm not sure I got that information. If it's not, investigate the fuse. If it is turning, maybe just keep on a trying
    I'm not sure what year your bike is.. Mine has a kick starter and that's an option, haha. And, there's always bump starting which is a crowd pleaser.
    1993 TW200
  1. Start but no start - please help -
    By rtf in forum Technical Help
    Last Post: 05-23-2013, 08:24 PM
  2. TW won't start
    By Vlakslee in forum Technical Help
    Last Post: 09-28-2011, 02:40 PM
  3. Won't start but will???
    By Lido in forum Technical Help
    Last Post: 09-12-2011, 07:37 PM
  4. TW no start
    By immgunn in forum Technical Help
    Last Post: 07-03-2011, 07:28 PM
  5. kick start won't start
    Last Post: 01-15-2011, 05:23 AM
2008 yamaha tw200 blowing fuse
how to replace a starter on a trail wagon tw200
how to test for the cause of blown fuse on tw200 yamaha
ignition fuse 2016 yamaha tw200
is there a fuse link on a tw 200
trail wagon tw200 runabout
tw 200 ignition fuse
tw200 battery advance auto parts
tw200 forum new battery still wont start
tw200 forum replaced main fuse bike still wont start
