1990 headlight question
Results 1 to 2 of 2
    Member Bizz's Avatar
    Apr 2013
    Inverness QC
    46
    I want to know if this is normal on older models (1990) the headlight turn on only when the engine is running? and the intensity of the light changes depending on the rpm
    my question is the headlight shoulds be turn on when I turn the key on?
    I do not speak very good English .. so sometimes what I write may seem foolish
    thank you for your understanding
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,710
    mine comes on as soon as I turn the key on. And yes, when the engine is running it has a bit more voltage for the light.
  1. round headlight / dual headlight
    By fredzaha in forum Performance and Customization
    Last Post: 05-04-2015, 01:32 AM
  2. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 10:52 PM
  3. 1990 carb Question
    By Gene-st1300 in forum Technical Help
    Last Post: 06-14-2012, 12:44 PM
  4. H4 bulb question / What headlight setup do you have
    By chines75 in forum Technical Help
    Last Post: 05-24-2011, 04:02 AM
  5. Headlight bulb question
    By darnold87 in forum Technical Help
    Last Post: 03-25-2011, 07:22 PM
