I told you so.... clutch spring
Results 1 to 10 of 18
Like Tree1Likes
Thread: I told you so.... clutch spring
    Junior Member cat 4 life's Avatar
    Jun 2013
    11
    Well..... I was searching on this site trying to find info on clutch adjustments, and kept reading about the "clutch spring" issue. I had glanced at mine and it appeared to be on but upon further inspection I found that it was improperly hooked. So, after fixing the problem my clutch enagement is now at about 75% instead of the more commonly found 90%+.
    So this is more of a "Thank You!" to all that have fixed/discovered this problem and were generous enough to share that information.
    I thought that it was just a fluke thing that showed up on random bikes but it appears to be more of an international problem as I am located in Canada. Which is all the more reason why I wanted to do this write up, because this goes beyond maintenance. This is production error.
    Anyways, thanks again.
    P.S.
    My list of fixes thanks to this site includes brakes and adjustments, mirrors, clutch spring, foot peg mod, oil change procedures and probably a few other things I can't think of right now.
    r80rt likes this.
    Member TheRedRider's Avatar
    May 2013
    Menominee, Michigan
    88
    What clutch spring issue? I've got clutch problems. What should I try?
    "keep it punched"
    Tennessee
    1,279
    Quote Originally Posted by the red rider View Post
    Using the search function. But really, the clutch spring is installed kinda backwards at the case sometimes. The picture here on the forum somewhere really helps show you what could be off.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,383
    Check this thread:
    https://tw200forum.com/index.php?/top...-check-spring/
    Jb
    May 2013
    Menominee, Michigan
    88
    Quote Originally Posted by jbfla View Post
    thanks. i think mine is ok.
    "keep it punched"
    Tennessee
    1,279
    If it's not at the spring, get your cables adjusted right and do an oil change with some moto oil. I won't go any deeper into what kind of oil because that's a can of worms or barrel of monkeys or something. A good chain adjustment can get rid of too much slop or too much play in the clutch as well, so consider that. If those fail you, it's time to get in there and do a little work.
    Member doggitter's Avatar
    Dec 2013
    Elmira, Oregon
    66
    Noticed some major slipping on mine tonight on a short test ride, after a little touch of it the other day. Knew I was in for a clutch job. I did a bit of poking around here, and this showed my spring is unlatched also. I'll pop it on and hope for the best tomorrow. Thanks again TW200Forum! Loren
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Did that solve your clutch issue doggitter?.
    Dec 2013
    Elmira, Oregon
    66
    It is way better than it was, but this morning it was still slipping just below full throttle on 4th and 5th. As it warmed up a bit the slipping went away. 1/2 hour of riding and no slipping. Thinking it'll be back again tomorrow probably?
    6,933
    The clutch on my parts bike was barely holding. I upgraded to some after market clutch springs and now all is well. Not a hard job but use a torque wrench.
  1. Brand new TW200 with the clutch spring issue.
    By invisibledove in forum Technical Help
    Last Post: 02-12-2018, 11:39 AM
  2. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  3. Clutch Spring?
    By nfpgasmask in forum Technical Help
    Last Post: 09-21-2012, 03:23 PM
  4. Clutch return spring
    By rwh7773 in forum Technical Help
    Last Post: 06-13-2012, 03:55 PM
  5. Clutch slipping? Check spring
    By 123elementm in forum Technical Write-Ups
    Last Post: 09-30-2010, 09:17 PM
