Camshaft removal
Results 1 to 5 of 5
    Member fredzaha's Avatar
    36
    I am removing this to be able to replace my valves
    But I am stuck here with these tabs that prevent me from unscrewing the bolts and removing the camshaft
    The service manual just says straighten the tabs. no other instructions or tools.
    Anyone know how to do this?
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Use a screwdriver and a hammer if necessary, just need to bend them enough to be able to spin the bolts.
    Jun 2011
    AZ
    793
    unbend them. When you reassemble you bend them back up to lock the bolts. Just a tab.
    36
    So i guess just force it
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Just take a hammer and a flat screw driver and gently tap them over.
  1. Air box removal
    By neimang in forum Technical Help
    Last Post: 06-21-2013, 10:27 AM
  2. ball bearing camshaft--anybody tried this?
    By JungleBiker in forum Technical Help
    Last Post: 04-08-2012, 07:11 PM
  3. camshaft/tach
    By phazer in forum Technical Help
    Last Post: 08-07-2011, 04:45 PM
  4. ? camshaft ?
    Last Post: 08-04-2011, 10:01 PM
  5. WTB Camshaft
    By TeeWee in forum TW200 Classifieds
    Last Post: 12-22-2010, 01:06 PM
how to remove the camshaft on a tw200
tw 200 camshaft removal
tw200 camshaft removal
tw200 camshaftremoval
