Oil Cooler capacity?
Results 1 to 3 of 3
    Senior Member Grant's Avatar
    Durbanville, Cape Town, South Africa.
    118
    I'm busy doing a standard oil change and I've got one of those POSH / Earl oil coolers mounted on the bike and I can't remember how much oil it holds??
    http://www.motobike.jp/data/motobike...t/TWcooler.jpg
    How much extra oil should I add?
    Thanks,
    G
    Desert, SoCal
    7,369
    Only adds a couple of ounces, tops. Even your high-rent tube-and-fin holds very little oil.
    Be careful not to overfill. The cooler will drain back to the crankkcase after shutdown. If you add too much it will pump itself out the vent on startup.
    Best way to determine exactly how much to add is to remove the cooler and lines, fill with water and dump their contents into a measuring cup, but I've measured a lot of coolers and you can be safe with adding a couple of ounces.
    Nice to see that the "competition" now has an adapter that faces forward instead of aiming directly at the stock exhaust pipe......
    Nov 2011
    norcal nutjob
    3,326
    still not as purty.....
  1. Mileage & Reserve Capacity
    By Mozart 2 in forum General Discussion
    Last Post: 06-10-2013, 09:08 AM
  2. Oil Capacity Question?
    By Swamp in forum Technical Help
    Last Post: 06-06-2013, 01:02 PM
  3. Extra fuel capacity
    By DonBenito in forum General Discussion
    Last Post: 01-15-2013, 07:18 PM
  4. oil cooler and engine oil capacity
    By AFISHALBIZ in forum Technical Help
    Last Post: 07-22-2012, 09:08 PM
  5. Doubled My Tank Capacity
    By bend42 in forum Performance and Customization
    Last Post: 08-26-2011, 10:42 PM
oil cooler capacity
oil cooler for xt225
tool tube tw200
xt225 oil cooler adapter
