Hole in the Exhaust
Results 1 to 2 of 2
    Junior Member lk555's Avatar
    Apr 2013
    16
    Hi guys, Iv got a 2002 tw 125, and on the silencer there is a small hole at the lowest point on the silencer. I don't know whether it is a drain hole for the bike, or someone has simply drilled a hole in the exhaust. I'm just confused because there is definitely exhaust gasses coming from this hole, and surely if it is a drain hole there isn't supposed to be the majority of the exhaust gasses coming out of it. Also, when I cover the hole, the exhaust gets a lot quieter and the throttle response is better. Any idea's?
    Hailey, ID
    3,308
    Quote Originally Posted by lk555 View Post
    Hi guys, Iv got a 2002 tw 125, and on the silencer there is a small hole at the lowest point on the silencer?
    If you are not talking about the hole at the end of the silencer where you access the screw to remove the back end, then yes, someone drilled a hole, probably in a misguided attempt to drain condensate. Just put a plug of JB-Weld in it.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. tw 225 exhaust ok?
    By dubstep in forum Performance and Customization
    Last Post: 10-11-2012, 04:51 AM
  2. Searching for that Fishin' Hole
    By TuggerHiller in forum Trails, Off-road, and Adventure Riding
    Last Post: 09-06-2012, 10:15 AM
  3. In search of Waterfall/swimming hole
    By evan in forum Trails, Off-road, and Adventure Riding
    Last Post: 05-21-2012, 11:47 AM
  4. Big gun exhaust for ttr 225
    By 530-TW in forum Performance and Customization
    Last Post: 05-27-2011, 07:49 PM
  5. Big Gun Evo Exhaust
    By betopimienta in forum Performance and Customization
    Last Post: 10-04-2010, 06:18 PM
