Clutch Slipping? Oil leak from Right Crank Case Gasket
Results 1 to 10 of 16
    Junior Member 1refuge's Avatar
    Jul 2012
    10
    Ok, This is my first post and I have little mechanical experience but I have spent a lot of time on the forum researching my issue. So Here it goes
    1999 TW with 1600 miles
    2nd owner
    The bike had 275 miles on it when I bought it last year. The guy literally just parked it one day, bought a Harley and never rode it again. It sat for about 13 years and was never ridden.
    I changed the plug, put carb cleaner and rode it on the road and some local trails last summer. Seemed to run rough but got me where I wanted to go.
    This year, had the carb cleaned, new fuel filter, and chain adjusted. My issue now is that the Clutch seems to slip really bad until the bike warms up. I have to use WOT in order to get it to move even
    a little. Once the bike is warmed up it will get going but still seems to slip once I come to a stop and have to take off again. Gears 1-3 seem to slip the worst and then 5th gear surges back and forth.
    I am getting horrible gas mileage, and now I have an oil leak coming from the right crank case gasket. (I assume from the WOT just to get it moving)
    My question is should I replace the clutch with only 1500 miles or is it something else. The clutch spring is in the proper position. The oil was just changed with 10w-40 synthetic motorcycle oil and I
    used the same weight last year just a different brand. Clutch cable was adjusted during Carb Cleaning. Any help you guys can offer would be great. This is a great forum.
    Junior Member Glaive's Avatar
    Sep 2012
    B.C. Canada
    Just curious what WOT means.
    Member TheRedRider's Avatar
    May 2013
    Menominee, Michigan
    89
    It's when you pin it.
    "keep it punched"
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Quote Originally Posted by Glaive View Post
    Wide Open Throttle
    Member deton8r's Avatar
    Washington State
    64
    So did this slipping start happening after the cable was adjusted? Almost sounds like it may not have been adjusted correctly. Did you replace the the handlebars or add bar risers? I just put some ProTaper ATV SE high bars on mine and I had to move my clutch able to the left and it's still a bit snug.
    '95 TW200G - TCI skid, ProTaper bars, amber Jimbo, DMO pegs, IRC GP-1, DG-O w/TTR230 header, Brisk BR12ZC, ProCycle jet kit, K&N filter, DID x-ring, TCI Sequoia rack, storage tube, JNS light
    '04 Buell XB12S Lightning - Drummer exhaust, race ECM, K&N, open airbox, RC right side scoop, Corbin seat, fender eliminator Michelin Pilot Power 2CT
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    What climate are you in (i.e. what temps)? What oil did you use and was that when this all started?
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Jul 2012
    10
    It all started after the carb cleaning and oil change. The chain was also adjusted and I was wondering if maybe it was adjusted too tight and creating too much drag on the engine. The Oil is 10w40 synthetic motorcycle oil which I used last year and I ride in mild temperatures in Michigan. The summer has not been hot. 70s and maybe 80s. Handle bars were not replaced and clutch feels the same as it did last year. Engages at almost 100%. I checked and the clutch spring is connected properly at the engine.
    My other question now is should I just go ahead and replace the clutch because I am going to have to take the Crank Case Cover off to replace the gasket anyways? I know there is an internal clutch adjustment as well and I am wondering if I should try that first. The bike had been sitting for 13 years and I'm wondering if the clutch is just messed up from sitting for so long. Anyways thanks for all the help and suggestions.
    Senior Member rm_hm's Avatar
    1,619
    Synthetic oil scrubs the innards of motors really good cleaning away crud that had built up from conventional oil around old gaskets. Then boom you have an oil leak.
    See the thread below for more info....
    https://tw200forum.com/forum/general-...synthetic.html
    I'm assuming you did the oil change by the book. Cleaned both oil filters and verified oil flow by loosening the oil bleed screw on the cylinder head?
    Here is a link to all of the slipping clutch threads
    https://www.google.com/search?btnG=1...w=1600&bih=767
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Did the oil you put in specify that it was for motorcycles with wet clutches? If the clutch didn't slip before the oil change, but does now, it's likely the oil is incompatible with wet clutches. If the leak isn't bad I would postpone fixing it until you can nail down the cause of the clutch slipping. With only 1600 miles you really shouldn't have to change the clutch unless it's been abused.
    May 2012
    445
    That's what I was leaning towards. The motor oil in a TW actually lubes the clutch as well and as RM stated it is not uncommon for a TW to leak after putting good oil in it, especial if it is too thin oil although that doesn't seem to be your case.
    I would try changing out the oil again, the one quart it takes is cheap and easy enough, to see if that fixes the issue before going into the more expensive and complicated possibilities. Don't under estimate the effect of oil on a single cylinder air cooled engine. The oil I upgraded mine to has made a world of difference in shifting, speed, engine temp, warm up and pretty much everything else. These engines run on air, fuel and oil.
  1. Oil leaking from crank case cover
    By MarcusPotts in forum Technical Help
    Last Post: 04-22-2015, 11:07 AM
  2. WTB right side crank case cover
    By arrowsmith in forum TW200 Classifieds
    Last Post: 05-23-2013, 07:48 PM
  3. ISO Right side Crank Case Cover
    By Puritan21 in forum TW200 Classifieds
    Last Post: 05-19-2013, 02:44 PM
  4. Oil being pushed out the crank case
    By okarmygrunt in forum Technical Help
    Last Post: 04-15-2012, 08:21 PM
  5. TDC Plug Stuck in Crank Case
    By Snake2715 in forum Technical Help
    Last Post: 08-10-2011, 08:26 PM
add oil to crankcase after oil inj delete blaster
blaster 200 right side oil leak
blaster clutch cover leaking
blaster clutch slip
blaster clutch slipping
crankcase leaks in tw 200 yamaha
howtoadjustclutchonattr225
oil leak 200 yamaha blaster
oil leak cover 200 yamaha blaster
removing right side crankcase xt 225
tw200 crankcase gaskets
what kind of oil goes in the clutch cover on a 200 blaster
