TW won't start?
Results 1 to 10 of 11
Thread: TW won't start?
    Junior Member rolo's Avatar
    Oct 2010
    4
    I have tried everything, need help? My 2004 TW, was sitting for a while. I replaced battery, cleaned carberator, replaced spark plug, changed oil.
    it does not start. It sparks and kicks, but does not start? any suggestions?
    Senior Member jontow's Avatar
    Oct 2010
    Potsdam, NY
    701
    Running new gas or old? If old: drain the tank into a suitable container,
    put some fresh gas in the tank, take the sparkplug out (leave the ignition off)
    and kick it a few times to clear anything out in the cylinder, then put the
    plug back in and try starting it as if it were a normal cold start.
    Otherwise, some folks have some specific procedures that work on their bikes,
    may or may not involve starting fluid, etc. Search the forum for those posts,
    someone may have a direct link to give you.
    Forgot to mention, if your bike doesn't have a kickstarter, do the same thing
    with the ignition on and *don't touch the plug* until the ignition is off.
    You'll hate yourself for a few minutes if you ignore that one..
    Good luck!
    1997 TW, well loved, a bit modified.
    Member glas482's Avatar
    1989 TW200 Cincinnati, OH
    63
    Are you trying to start it in gear with the kick stand down? Or maybe the switch itself is messed up.
    89 TW200
    08 V Strom DL650
    71 Honda CB350
    Senior Member Petrus's Avatar
    Africa
    458
    Did you try a running/push start?
    2008 TW200
    BC
    623
    Try some ether (aka "Cold Start" spray)...for some reason, these bikes are notorious hard-starters if left idle for any time.
    2008 TW200
    Southwest corner of BC Canada
    jvt
    jvt is offline
    Senior Member jvt's Avatar
    Enumclaw,washington
    136
    Did it run when it was parked?
    Oct 2010
    4
    STill no go. This is electric start. I made sure the spark plug was sparking, did recieve good spark. I am about to give up. I tried all facters.
    To run, any gasoline engine requires compression, fuel, and spark. If you have compression, it has to be either fuel or spark. If it has compression and spark, it has to be fuel.
    Does the engine turn over? If not, try push starting the bike.
    If the bike ran when parked, 99.9% of the time the carb needs cleaned. I'd go back and go through the carb to make sure all is well. I don't mean just pull the carb off and blow some carb cleaner in the passages, I mean a total disassembly, inspection, and cleaning of each and every part. If I had a dollar for every recently cleaned carb I rebuilt and the bike ran fine, I'd have enough cash for a trip to Alaska.
    Oct 2010
    Potsdam, NY
    701
    I agree with the above: if starting fluid won't make it fire up (have to do this on my old blaster
    every single year) and at least burn off the vapors, you've got ignition/compression issues.
    Chances are, qwerty's nailed it and the carb needs a full disassembly, inspection, and cleanup.
    I'll add one thing to the needs of a combustion engine: the proper amount of air.
    One quick test that doesn't involve pulling the carb: hook a hose to the bowl drain on the carb
    and drain it all out with the petcock shut off, then turn the petcock on and crank it for a bit.
    After that, turn the gas off again and drain the bowl once more. If you don't have plenty of
    good clear fuel the second time, your float is stuck closed, the filter screens are plugged,
    or your bowl drain is plugged from the sediment and varnish in the bottom.
    Make sure the air filter is clean, the petcock screens both in-tank and in the assembly itself are
    clean. Double check that you didn't end up with cracks in the rubber intake from sitting, and check
    that the local field mice haven't decided to make base camp in your air filter housing. Been there.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by jontow View Post
    Spider webs, mice or wasp nests...
    people have found many things blocking the air.
    Stephen S.
    '07 TW200:
  1. Start but no start - please help -
    By rtf in forum Technical Help
    Last Post: 05-23-2013, 08:24 PM
  2. TW won't start
    By Vlakslee in forum Technical Help
    Last Post: 09-28-2011, 02:40 PM
  3. Won't start but will???
    By Lido in forum Technical Help
    Last Post: 09-12-2011, 07:37 PM
  4. TW no start
    By immgunn in forum Technical Help
    Last Post: 07-03-2011, 07:28 PM
  5. kick start won't start
    Last Post: 01-15-2011, 05:23 AM
my tw200 wont start
tw 200 doesnt crank
tw 200 has spark wont start
tw 200 will not start
tw200 cranks no start
tw200 electric start wont work
tw200 wont kickstart
tw200 wont start
yamaha tr200 wont start
yamaha tw 200 wont start
yamaha tw compression lost through carb boot
yamaha tw200 wont start
