rear axle bearing help
Results 1 to 8 of 8
    Member mkriley's Avatar
    Jun 2011
    71
    hey all,
    My right side rear axle bearing bit the dust and the center part and bearings fell out.
    The outer race is still firmly stuck in the hub trapping the inner spacer inside. as it will not clear the race to be removed. the spacer prevents the use of a bearing remover and also give no way to use a drift from the other side. Should I try to use the spacer to hammer the double bearing set out? Seems like a bad idea. Anybody gone through this?
    mike
    Junior Member Joboo's Avatar
    May 2013
    22
    I am having a hard time getting a visual picture on this situation. Please bear with me as IDK your skill set and what tools you have to your disposal. Before going to the hammer, do you have a torch ? maybe some heat would help loosen it up. Try some good penetrating oil first. last but not least bust out the hammer and go easy. If you can post a pic that would be great!
    Ephrata, WA
    1,125
    I wouldn't hammer on the spacer. It takes a lot of effort to hammer out the double stacked bearings. Post up some pictures when/if you can please.
    1990 TW200
    Jun 2011
    71
    not much to see as the double bearings are intact and the single has lost everything but the outer race.
    the spacer is trapped behind the race by the flange on the spacer. it prevents my getting a drift in and punching out the races on either side.
    does the spcacer nomally clear the outer race? the spacer also keeps a blind bearing puller from getting in behind the bearing.
    how does one go about removing the bearings if they are intact?
    mike
    Quote Originally Posted by Rainman View Post
    Ephrata, WA
    1,125
    Quote Originally Posted by mkriley View Post
    mike
    I gotcha. Can you use a blind bearing puller and remove the stacked bearings one at a time? The outer edges of the bearings are slightly tapered so a blind puller will go between the two stacked bearings. Then the spacer will fall out and you can use a drift to drive out the problem bearing.
    1990 TW200
    Senior Member Toyanvil's Avatar
    Sep 2012
    Bakersfield CA
    234
    I would take it to a good auto machine shop. In the old days when I worked on cars for a living we would use a slide hammer with ajustable jaws that would grab the outter race in the groove where the bearing would have been, they probably have something better by now. If you have a welder, weld a piece of flat bar across the bearing race and drive it out with a long drift from the other side.
    Good luck
    09 TW200
    04 BMW 1150GS
    61 Sunbeam Alpine
    Jun 2011
    71
    got it done.I put the double bearing set on the bottom, tire on sawhorses and put the axle bolt in from the top to align the spacer tube and used a brass drift on the top of the axle bolt and hammered with a BFH 5lb. they came out while turning the drift into a pretzel.
    no damage to the bolt or spacer.
    thanks all
    mike
    BTW signs of water in the axle assembly these bearings are not waterproof.
    Quote Originally Posted by Toyanvil View Post
    Good luck
    Ephrata, WA
    1,125
    Glad you mentioned that. Even the new All Balls bearings I put in a few years back get water in them. Its important to check them periodically.
    Good job on getting the bearings out.
    1990 TW200
  1. Hollow rear axle please..
    By rebar in forum General Discussion
    Last Post: 06-18-2013, 06:08 AM
  2. rear axle won't come out.
    By scott in forum Technical Help
    Last Post: 09-21-2012, 10:18 PM
  3. Reversed rear axle bolt.
    By Trikstr in forum Performance and Customization
    Last Post: 09-02-2012, 09:09 PM
  4. Steering bearing replacement
    By Rainman in forum Technical Help
    Last Post: 02-21-2012, 05:12 PM
  5. Rear axle bearings
    Last Post: 12-24-2011, 09:25 AM
outer race stuck in axle tube
