AMR coil installation
Results 1 to 4 of 4
    Member dutchbat's Avatar
    Dec 2012
    Holland
    46
    I recently bought the eBay AMR racing coil and have found a bug in the design..
    the ground plug that normaly is pinched between the coil and frame is blokked by a peace of plastic that sticks out of the coil
    body where the spark plug wire is coming out of the plastic.
    Is this plastic removable or should i just turn around the coil somehow..
    the TW manual obviously doesn't say anything about it.. so I'm quite nervous of the consequenses of installing the coil in a different mannor than the old
    coil was installed.
    any help?
    thanks.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    I can't recall offhand how I wired it, but don't think there was any problem.
    Right now my TW is in a different state or i would go look. Maybe this photo will help.
    jb
    Member deton8r's Avatar
    Washington State
    64
    jbfla - is that wire wrapped around the coil wire for a tach?
    '95 TW200G - TCI skid, ProTaper bars, amber Jimbo, DMO pegs, IRC GP-1, DG-O w/TTR230 header, Brisk BR12ZC, ProCycle jet kit, K&N filter, DID x-ring, TCI Sequoia rack, storage tube, JNS light
    '04 Buell XB12S Lightning - Drummer exhaust, race ECM, K&N, open airbox, RC right side scoop, Corbin seat, fender eliminator Michelin Pilot Power 2CT
    FL. GA, NC
    2,399
    Quote Originally Posted by deton8r View Post
    Yes, it's the wire from the tach I have mounted with velcro to the top of the TW's brake fluid reservoir.
    It's one like this, but not labeled Yamaha. There is a bit of a lag time before the tach catches up to the actual rpm's.
    jb
  1. Pulser Coil
    By queenpdog in forum Technical Help
    Last Post: 05-22-2017, 01:12 PM
  2. Ignition Coil
    By BC4Lyphe in forum Technical Help
    Last Post: 04-02-2013, 08:24 AM
  3. 2010 pick up coil
    Last Post: 10-29-2012, 10:44 AM
  4. 12V at coil?
    By ldw72120 in forum Technical Help
    Last Post: 08-25-2012, 07:09 PM
  5. Pulser coil
    By SirSmighty in forum Technical Help
    Last Post: 10-06-2011, 02:42 PM
amr coil for tw200
coil
tw200 racing coil
