Front brake fluids
Results 1 to 3 of 3
    Member dutchbat's Avatar
    Dec 2012
    Holland
    46
    Front brake fluids
    I NEED HELP dudes,
    Recently my front brake jammed up. after a big check up i discovered a s*** load of problems.
    my calliper cilinders were jammed, my front master reservoir piston was jammed and my brake fluid was very dirty..
    I have ordered all nececery parts and fluids but very quickly ran into a problem.. i can't fill my brake system through the normal route..
    -i filled my fluid reservoir
    -started pumping..
    only small bubles of air came out of the little breathing holes in the reservoir body..
    am i doing something wrong? or is this a sign of something realy bad or stupid?
    any help would be awesome.
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    If the reservoir isn't sealed up then you cannot create pressure by pumping up the breaks. I also find it easier on bikes to just gravity bleed them, that is leave the cover off the reservoir and open the bleeder valve. Make sure you keep the reservoir from running empty though or you will just add more air to the system.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Old thread I know ,but, "reservoir isn't sealed" meaning the reservoir cap is not secured / on ?.
  1. Front brake '99 - '01
    By dutchbat in forum Technical Help
    Last Post: 05-25-2013, 05:46 AM
  2. front brake hose
    By 671tdub in forum TW200 Classifieds
    Last Post: 01-11-2013, 04:47 PM
  3. Front brake rotor
    Last Post: 12-02-2011, 08:15 PM
  4. Front Brake Pads
    By Hendragster in forum Technical Help
    Last Post: 10-08-2010, 04:01 PM
  5. WTB - Front (brake) hub.
    Last Post: 09-24-2010, 01:14 AM
