Help - Fork Oil Change / Service - Clarification Needed
Results 1 to 4 of 4
    Member canadainshiver's Avatar
    Oct 2011
    New Brunswick, Canada
    77
    First off, I'll say I've ready the Sticky's... several times. They are great, and my hats off to the guys for making those!
    Perhaps my reading for comprehension isn't up to snuff. I can't figure out what size the 'homemade tool' (nut) needs to be to remove the damper rode. I read 'it is a 19mm'. What is? The socket? the size of the nut used? I've also read to use a '12mm'. A 12 mm nut didn't work for me - way too small.
    Help would be greatly appreciated! Currently at a standstill with my rebuild.
    1991 TW200 Hidden Content
    Oct 2011
    77
    I'm an idiot... I think I've just figured it out.
    Is there a way to delete a thread?
    Sep 2012
    Northwestern Oregon
    1,092
    Just to clarify (although it sounds like you already figured it out): You need something that is hex shaped and 19mm across the flats. A 12mm threaded nut or coupling typically is 19mm across the flats. I bought a 12mm threaded coupling and it worked perfect.
    Senior Member Trikstr's Avatar
    Jun 2012
    Oak City, UT
    156
    If I remember correctly I used 3/4" hex stock. A 3/4" nut on some all-thread with either a 90 deg. bend or a T-handle welded on should do the trick.
    '99 TW,Ricochet skid plate, Seat Concepts, Jimbo shield, 2" extended swingarm w/Maxxis Bighorn, 5.10 Kenda K270, Stealth exhuast, YZ80 hybrid front forks w/HyperPro proressive springs, ProCycle high mount front fender, ProCycle wide foot pegs, TT-R stainless head pipe, Lizrdbrth cooler, D-Flex hand guards, XT350 gas tank.
    2002 Honda Spirit Shadow VT750
    1987 BW350
    '78 Honda XL100
  1. What is needed for Fork Seal replacement?
    By glas482 in forum Technical Help
    Last Post: 11-13-2016, 06:40 PM
  2. YZ80 fork input needed
    By pgilles in forum Performance and Customization
    Last Post: 11-08-2012, 04:22 PM
  3. Fork Service - A TW Without Forks is Like a Duck Without a Bill
    By admiral in forum Technical Write-Ups
    Last Post: 02-28-2012, 07:58 PM
  4. Replies: 15
  5. Probable cam-chain noise - clarification requested.
    By turborob in forum Technical Help
    Last Post: 11-21-2010, 02:03 PM
replace tw200 fork oil
