First time I've checked mileage. Hard to believe?
Results 1 to 9 of 9
    Member moresnow's Avatar
    Oct 2012
    Iowa
    75
    Stock '09. 68 miles and 0.66 Gal. Seems unreal. I am at approx. 900' elevation and temps in the low 80's. Cruising mostly gravel with a bit of black top averaging 40 to 50 mph. Everybody else getting mileage like this?
    Senior Member nfpgasmask's Avatar
    Nov 2010
    Reno, NV
    500
    I get 70-80 miles per tank on my bike.
    Bart
    Junior Member chazk3's Avatar
    Jun 2013
    Michigan
    29
    I figured roughly 72 MPG over my first 2 tanks. I have a spreadsheet to track it, so will be able to post more accurate MPG over time.
    May 2012
    Tucson, AZ
    976
    Quote Originally Posted by moresnow View Post
    My best couple of tanks mpg wise were around 100mpg, so you're not alone. I was similarly astonished.
    With varied city, highway, and dirt miles I typically run anywhere from 70-90mpg.
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Aug 2011
    Cayce, SC
    3,109
    I have a few bikes and numbers are hard to keep track of but I believe that there is 1.3 gallons before hitting a .5 gallon reserve. I hit reserve anywhere from 75-100 miles. So I get something like 55-75 mpg. This is likely to be a lot lower is you only ride offroad. With my three dual sports I hit reserve around 90 miles so I can comfortably get 100 miles off of a single tank on any of my bikes. Funny how all the different sized tanks all have to be refilled at the same time.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member rurlndum's Avatar
    Jun 2013
    462
    I never take my TW200 over 35 mph because I don't have to. Running in 5th gear at 35 mph and under on asphalt and gravel roads I am well north of 100 mpg.
    You want to go faster? Buy a cheap second bike on Craigslist.
    But not everyone lives in a small valley in rural northern Nevada. Haven't seen another car in quite a few days. And don't want to.
    My TW200 is geared about the same as my vintage John Deere. Maybe I'll start using it to pull tree stumps out of the ground even with the 15-50 sprockets.
    Oct 2012
    Iowa
    75
    Thanks for all the replies. I'm really amazed at the mileage. I was not riding it with intentions of getting high mileage either!
    Senior Member Swamp's Avatar
    Apr 2013
    Michigan Territory
    108
    I get 85 mpg consistantly! I check my miles against the amout of fuel after every fill up! My commute is all paved, with 45 mph being the fastest speed!
    Swamp
    2006 TW200
    Senior Member BillMichaels's Avatar
    SF Bay Area
    275
    My Brother and I took a ride up to Sonora pass a couple weeks ago (3000' to 9624').
    116 miles ...... 1.1 gal gas
    Looks like over 100 mpg
    Bikes were really starving for air the last 2000 feet but both ran great.
    1998 HD FLHTC
    2004 TW200
    2004 TW200
  1. Long time lurker, first time poster
    By TW-Brian in forum General Discussion
    Last Post: 08-30-2014, 02:59 PM
  2. mileage
    By plumbstraight in forum Technical Help
    Last Post: 05-06-2013, 08:20 PM
  3. Video time... (big-time stuck!)
    By bookm in forum General Discussion
    Last Post: 05-30-2012, 09:54 PM
  4. Mileage
    By Pinittowinit in forum General Discussion
    Last Post: 09-29-2010, 08:31 AM
  5. Mileage
    By WINGNUT200 in forum Performance and Customization
    Last Post: 08-25-2010, 09:37 PM
