exhaust and rejetting clarification + project pics
Results 1 to 3 of 3
    Junior Member Cretus's Avatar
    Jun 2013
    Austin, TX
    8
    I have installed the DG slip-on exhaust, took it for a drive today and noticed that when i was around 50-60mph, i would get hesitation when reapplying the throttle from backing it off. my question is.... is this the characteristics of needing to re-jet after the aftermarket exhaust is installed? it seems my idle was much better and the power at low speeds also seemed to improve since replacing the stock exhaust...
    some pictures of my project so far.
    Aug 2011
    Cayce, SC
    3,109
    You may want to raise the needle a bit and/or get a larger main jet.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Jun 2013
    Austin, TX
    8
    thanks! i figured it needed to be done, just wanted to make sure before i dig into the carb....
  1. Help - Fork Oil Change / Service - Clarification Needed
    By canadainshiver in forum Technical Help
    Last Post: 07-10-2013, 09:02 PM
  2. Rejetting help
    By nfpgasmask in forum Technical Help
    Last Post: 01-25-2013, 09:41 PM
  3. My 88 project
    By trailway in forum Performance and Customization
    Last Post: 12-21-2012, 04:01 PM
  4. Damage while rejetting
    By dganey in forum Technical Help
    Last Post: 03-21-2012, 12:20 PM
  5. Probable cam-chain noise - clarification requested.
    By turborob in forum Technical Help
    Last Post: 11-21-2010, 02:03 PM
rejetting
rejetting for dg muffler on tw200
using a dg exhust with stock main jets on my yamaha tw 200
yamaha tw200 exhaust rejet or not
